New LS1 Owners - Newbie Tech - Exceeding Redline In 1998 Trans Am With Automatic Transmission?
REDHOT7
08-02-2012, 01:21 PM
I have a 1998 Trans Am with an automatic transmission. I've been wanting to see what my 0-60 and 1/4 mi. times are, but I was told by the dealership that the 1998s are not equipped with a rev limiter. I realize I can blow the transmission by downshifting at high speed, but in a 1/4 mile or 0-60 time test, there's no reason I'd ever need to downshift -- only upshift. So my question is this: If I leave my automatic in high gear at the start line, and then stomp on it when the flag goes down, will my transmission ALWAYS upshift to the next gear before I reach redline, no matter how hard I drive it? I've looked all over your forum for the answer, but I can't find it. My fear of overreving my engine with no built-in protection, and the huge cost involved if I do, is what's keeping me off the track. I'd appreciate it if only members with extensive background in racing and/or automatic transmissions answer this question. In other words, gearheads :angel: not boneheads. :eek2: Thanks!
Fry_
08-02-2012, 02:04 PM
The guy at the dealership is a moron. Your car has a rev limiter, 6200 or 6300rpm if think. If 98's didn't have rev limiters then mine would be dead after missing 3rd gear at the drag strip a few months back. Also assuming your car doesn't have anything wrong with it's transmission it will upshift for you when you leave it in high gear, in fact that will more than likely net you your fastest time.
RPM WS6
08-02-2012, 02:08 PM
My advice would be to never return to that dealership for information such as this ever again. They are completely wrong. Rev limit for your '98 is set to 6200rpm in the stock PCM.
The 4L60E is controlled by the PCM, and it will prohibit manual downshifts above certain speeds for certain gears (if you manually put the shift level into 1st gear at 100mph, it will not allow this to acutally happen within the transmission).
Yes, assuming that there is nothing wrong with your transmission causing it to slip or shift late, etc. And assuming that you have stock tuning or aftermarket tuning that has the proper relationship between shift points and the rev limiter (you don't want to set the rev limit and shift point to the same rpm, there needs to be a window between the two - the stock window was 200rpm [shift point at 6000, rev limit at 6200] but you can usually get away with as little as a 100rpm window if your trans is in excellent working order).
Unlike a manual trans car, you can't mechanically overrev a 4L60E car, so unless you remove the rev limiter via tuning, this should not be a concern.
Well, I've owned four of these cars (LS1/4L60E combos), and in those cars I've owned four stock 4L60E transmissions and two "built" 4L60E transmissions. One was tuned by a shop, and the other was tuned by me. I've raced with both the stock and built versions of these transmissions.
Hopefully my experience/resume is good enough. :)
LS-ONE_DAY
08-02-2012, 02:14 PM
Wouldn't cut it for me :eyes:
Just kidding of course!
01BlueSS1995
08-02-2012, 06:05 PM
Everything said above, but put it in 3rd, not overdrive!
Fbodyjunkie06
08-03-2012, 08:34 AM
Nail just got hit on the head.
raptorblackBird
08-06-2012, 04:49 PM
my 98 TA really impressed me in terms of being idiot-proof. That's an excellent improvement in terms of technology, because I am one of those idiots sometimes
Posted from LS1Tech.com App for Android
wooddaniel
08-07-2012, 10:14 AM
Never ask the dealer anything performance related. Very rare that they will know their ass from a hole in the ground.
LS-ONE_DAY
08-07-2012, 11:40 AM
^This
When I asked for header bolts at the local dealer for my header swap the guy looked at me and said oh you're replacing the exhaust manifolds? Do you need those also? And I simply said yeah something like that and no I have it taken care of, do you have the bolts? Couple minutes later I had what I needed without trying to tell them anything more than they needed to know and not allowing them to give me "advice"
NC98Z
08-07-2012, 12:23 PM
Don't ever manually shift your tranny. You'll burn your clutchs out downshifting and waste your time upshifting because the CPU controls the shift. Not you. You need alittle dragstrip time!
2k firehawk
08-17-2012, 12:40 PM
Op let me know if you decide to hit the track i want to get my hawk out there
REDHOT7
11-13-2012, 12:29 PM
Thanks guys. I really appreciate your answers and it does take a load off my mind. It amazes me though that the Service Advisors (more than one) that I questioned about this didn't know the 98s have rev limiters. After I got your answers, I did some internet research and came across tons of online parts stores that carry stock as well as upgraded rev limiters for 98 Trans Am's. Absolutely amazing! So it's time to hit the track now!
pnykillerz28ls1
11-13-2012, 03:24 PM
. It amazes me though that the Service Advisors (more than one) that I questioned about this didn't know the 98s have rev limiters.!
monkey see monkey do :jest:
RPM WS6
11-13-2012, 03:41 PM
Frankly, I would be more amazed if an average service writer actually knew the correct answer in the first place. :)
777Shock777
11-16-2012, 02:32 AM
Yep, just put it in the 3rd gear, it will ride it longer instead of going to Overdrive if you were to leave it there.
murphinator
11-17-2012, 06:59 PM
do yourself a favor do not buy ANY performance parts for your car without asking about it here first because there is no part that is a stock or upgraded rev limiter , it is all computer code inside your pcm that should only be messed with by someone recommended by the people into these cars - forum members.
forum members will watch your back while you figure out what you have and what to do with it:chug:
Brittany Jade
04-11-2013, 04:20 PM
Glad I came across this thread... New owner of 98 Trans and can't wait to hit track...
