My2kz28
08-02-2012, 04:39 PM
1996 Pontiac Firebird WS6. It was just involved in an accident and I’ve decided to sell the car out for a parts car. It includes a lt1, bored .30 over to 355 cubic inches and has 9:1 compression SRP forged pistons and eagle forged rods. Also has TPIS stage 2 ported heads, arp everything internally, and a 224/236 114 ls1 cam with around .550” lift both intake and exhaust. This motor was built by rmcr in the springs and have all receipts. It also has a PTK front mount turbo kit with a master power GT45 turbo on it making 10psi now. It is jet hot 2000 coated. Comes with a tial 38mm wastegate and a 50mm turbosmart blow off valve. Downpipe was damaged in the accident, but can be fixed to 3 inches. Car has a stock t56 6 speed trans, and a moser 9 inch rear end with 4.11 gears. It has a 255 walboro fuel pump in the tank, and a vortech inline booster pump. This car made 610 rwhp on a chassis dyno in the springs..
Damaged parts that cant be reused: Tubular k member, passenger ls1 spindle, probably the other spindle too, the griffin radiator stood up vertical is busted, but has 2 high performance spal puller fans on it that are good.
So basically this is a great steal for someone technically inclined. It has thousands of dollars invested. You will need a bmr kmember, cheap 31x21x4 ebay intercooler, griffin radiator (can get part number) and you have a front mount turbo lt1. Also has an eboost electronic boost controller.
What do you guys think something like this is worth?
