pp 5.7 stage 2 heads with 231/237 (( a4 ))
what do you think a buot my mods with pp 5.7 stage 2 heads with 231/237 cam . (( tuned )) is daily dirve or what ?
i'm really confusing a bout that go with 231/237 or 224/224
my goal is low 11's and keep daily drive .
please help ... i'm los'n my mind
Originally Posted by foff667
I'll let you know once i get mine started and tuned should be fine as long as you have a decent sized converter.
so all i need just high stall and good tunning to use it daily drive .
I THINK IT WILL BE VERY LOUD AND NOIS FOR STREET , IS THAT RIGHT
LS1Tech Premium Sponsor
For streetability, the 231/237 will work fine with your 3200 stall torque converter, but the car will run much quicker with a higher stall speed. If you are wanting a cam that will work well with your 3200 stall speed torque converter, then I'd recommend our 224R camshaft (224/224, .581"/.581", 112 or 114 LSA). I picked up 40 RWHP with this camshaft and stock heads in my '02 SS.
Feel free to call or e-mail me at trevor@texas-speed.com if you have any other questions. I'll be glad to help you select the right setup that will work well for your needs.
Trevor
Texas Speed & Performance
Trevor
Trevor
Trevor
Thank you very much.
I’ll order cam package soon
My regards
Originally Posted by gomer
Maybe Nick Y will chime in on this post. He's running the 231/237 in a 2003 A4 vette. He had some initial surging troubles, but cartek got the tune right on it. If you have a competent tuner that will work with you on it, I say go for it. I hope you have a 3800 or larger stall too!
hey gomer,
i have been im indy and gave him my thoughts, i think that he'll need a bigger stall for sure. i cant stress it enought that the major part of the puzzle is a killer tune!!
btw the weather was crappie at vette shouout on sat i didnt go
indy the im that is sent is pretty much what everyone is telling you. trevor nailed it by saying car would be alot faster w/bigger convrt, just like i told when i had 3000 restalled to 3800!!!!!!!!!!!!!!!! the cam is a waste w/out!!!
to feel the cam you need stall!!!
Don't rule out the 231.231 camshaft also, it offers a middle between the 224 camshaft & the 231.237 cam
Jason
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
