Car makes noise when backing up and sharp left turn?
Old 08-02-2012, 05:58 PM
HarleyZ28's Avatar
Default Car makes noise when backing up and sharp left turn?
My car has been making noise when backing up, kinda like a old wooden bed if you roll around on it, or maybe a growling sound???
Also I was driving around the neighborhood and made a sharp left turn and heard the noise also.
Car has a moser 12 bolt with eaton posi 4:10 gear.
Old 08-02-2012, 06:49 PM
FAD2BLK93's Avatar
Struts? Check the driveline u joints they may need some grease.
Old 08-02-2012, 06:54 PM
FAD2BLK93's Avatar
When u drive down the road and sway it back and forthdo u hear the sound on one side or the other? If so u could need a hub.
Old 08-02-2012, 11:08 PM
shbox's Avatar
If it is coming from the rear, it may need some limited slip additive.
Old 08-03-2012, 11:44 AM
GREGG 97Z's Avatar
The rear would leak a bit through the vent tube for some reason, there is a clear plastic tube on the top left side. I would check the fluid level and add some 80w/90 gear oil. I ran non synthetic in there, it is supposed to be better for these rears than synthetic. I also used a small bottle of LSA when I changed it last.
Old 08-05-2012, 08:02 PM
HarleyZ28's Avatar
Lately I've been paying more attention to this sound, when I slow down and hit the brakes its making the sound, also when pulling up a steep drive way slowly it makes the sound.
Its not a popping sound more like a squeaking sound.
Old 08-05-2012, 09:50 PM
FAD2BLK93's Avatar
It wouldn't actually be the brake pads, or possibly the indicators? Right? Start there. Then i would move to the driveline then the diff. Put the car in the air and see if it makes the sound. Or if there has to be a load on it.
Old 08-07-2012, 04:25 PM
HarleyZ28's Avatar
So I added fluid to the rear end, and still makes this noise.
It is most noticeable when pulling slowly up into a steep driveway, or backing up...
It sounds like its coming from the right hand side on the rear.
I am starting to wonder if this could be in the suspension, however it makes me wonder if it is the suspension, why would it do this also while backing up?
Old 08-07-2012, 04:30 PM
Village Troll
SS RRR's Avatar
As stated, check your brake pads to see if they are low.
Old 08-07-2012, 04:41 PM
Z28RS's Avatar
My old '98 V-6 Camaro made a noise similar to what you described when I drove it in reverse. I believe that new rotors and pads solved the problem.
Quick Reply: Car makes noise when backing up and sharp left turn?
