3.4l to LT1 swap no start
Hey guys just looking for a little bit of input. Like the title says I swapped my firebird's 1994 3.4l V6 A4 for a 1993 Z28 LT1 A4. I bought the entire Z28 car and did the swap straight across to my car; engine, cradle, transmission, harness and compuer. When I turn the key to run everything turns on; lights, radio, accessories, etc. When I go to turn the engine over nothing happens, no fuel pump, no starter, just silence. I tried the resistor mod with the resistances of my car and then again with the resistance of the Z28, neither worked. Just today I put on the VATS bypass module from Hawks Third Gen and it also did nothing. Triple checked all grounds from ECM and starter. I'm just out of ideas outside of a total ECM replacement. I know this a persistent, annoying question on all f-body forums but I've searched and tried every option that I could find. Appreciate any advice or ideas that you all have.
Yeah the starter will crank if I cross it but that's it. I've not tried to spray any starter fluid down the intake while crossing it but even if I did I'm not sure what that would accomplish lol.
By crossing the starter i am trying to see if its the starter not firing the motor. It did not so i am thinking its a sequrity issue. Because it seems the injectors are not firing either. See if u have power and ground to the injectors. Because its the computer that grounds the system after a sequrity check.
The ECM is not going to cause the starter to not engage. Sift through the schematic for the starter circuit and see why you are not getting the solenoid energized.
