Titanium Retainers
Old 04-04-2004, 04:55 PM
Naked AV
Guest
Posts: n/a
Default Titanium Retainers
Comp told me to get their retainers (to go with their cam) at $195. Is there a better deal for an equal product out there?
Old 04-04-2004, 05:17 PM
TVWilkes's Avatar
What type of springs do you have?
Old 04-04-2004, 05:31 PM
santino04's Avatar
All titanium retainers will be a lot more expensive than steel ones, and its worth the money. you can usually find them for 10-20 bucks cheaper at any of the sponsors here usually. Im sure you know weight plays a big part in the valvetrain, the lighter the valvetrain the faster the engine revs. I think titanium is like half the weight of steel, its only a few grams off the end of valves, but it makes a difference in adding a couple hundred more rpms before your valves float. Good Luck
Old 04-04-2004, 05:36 PM
c5blkvette's Avatar
I got my comp cams titanium retainers from racenet.net for $170 ...be prepared for a bit of a wait though (3-weeks for mine)
Naked AV
Guest
Posts: n/a
I'll be getting Comp's 26918 springs at their recommendation, to go with the 772 retainers. I'm installing a mild cam, their 54-412-11.
Old 04-04-2004, 06:24 PM
jrp
SN95 Director
jrp's Avatar
should of got the manley kit, springs good for .600 lift and tit. retainers for 178 from SDPC
Old 04-04-2004, 06:31 PM
Blacker's Avatar
That is what I am using.
Old 04-04-2004, 07:02 PM
Naked AV
Guest
Posts: n/a
I don't have anything yet except the cam.
Old 04-04-2004, 07:49 PM
TVWilkes's Avatar
The Patriot "GOLD" dual spring kit cost $295.It includes springs,retainers,seat bases and seals.
Old 04-27-2004, 12:26 PM
Zanthius's Avatar
I took JRP's advice and got the Manleys from SDPC for $178. Just did my cam install. Can't complain.
