Footlead
08-03-2012, 12:23 AM
1968 Camaro Drag car. Dart BigM Fresh 505 cubic inch Rat. Eagle 4340 4.25 crank, eagle 6.385 HBeam Rods. JE Pistons, Brodix BB2 Heads Ported, Jesel Belt drive, Jesel Rockers,Crank Trigger, Moroso vacuum pump, Lunati Cam, Lunati Lifters, 1050 Dominator, 2 speed Glide. with Pro Brake, 9. inch TCI Convertor, 9inch rear/4.56 gears/spool. Very Nice Clean car. Hardy Williams Silver 68 Camaro.Stock suspension with all upgraded parts. Full cage Mini tubbed. Weld wheels with new 28.5 x 10.5 s stiffwall MT slicks . Also Intake is drilled for a Fogger system and it has a Big Shot Plate NOS kit on it with all the safety Hobbs switches. Two fuel systems etc etc. MSD 7al-22. Lexan except the windshield. The car has all the good stuff on it. Car will run 5.xx on 200 shot. and is built to take alot more. car weighs 2900lbs. Nickens built the Motor. Call Hardy @ 936-336-0644 for all of the info $19,950.00 e-mail jairw1@consolidated.net for pictures. The car is in Montgomery Texas. Very Clean car can be put back on the street easily.:cheers:
