Cadillac CTS-V - USA SPEC install question
View Full Version : USA SPEC install question
sod
08-03-2012, 12:37 PM
Hey guys,
I'm going to install a USA SPEC PA-15 VETTE this weekend.
I see that the kit comes with an extension cable, I guess to relocate the "box" somewhere other than the rear deck lid. My question is, will I need to use the extension cable? The iPod cable is only 6 ft long & I'm planning on running it into the center console. Will I be able to run a 6 ft long cable from the rear deck lid to the center console? I'm not quite sure how to route the cable, so if anyone has first hand knowledge of the install, I'd appreciate any pointers.
Thanks & have a good weekend!
NeverSatisfied02
08-03-2012, 12:47 PM
You'll definitely need the extension cable. I put my module up under the carpet on the passenger side of the car and ran the iPod cable up from there so it was clean and gave me room to adjust the length of the cable to where I needed it.
CTS-V2
08-03-2012, 12:58 PM
Hey guys,
You will need it most likely. I ran mine under the carpet in the rear center and it is under the passegner seat. I am not going to lie... it is a stupid install at how much crap you have to take apart. You basically end up taking the entire rear of the car apart for a stupiid IPOD jack! But thats only because the cadillac radio is terrible and unless you do something custom for thousands, you are stuck with a crappy nav and radio! Ok, I ranted I am better now lol
FuzzyLog1c
08-03-2012, 01:33 PM
Running the cable under the carpet over the transmission hump is the worst part of the installation (other than taking the back of the car apart). Unless someone has a better idea, grab yourself a coat hanger and use it to pull the extension wire under the carpet to the center armrest area. The head unit is small enough to fit under the center armrest assembly, although you'll have to really fiddle with it to get it to fit. If you need a hand, send me a PM and I'll toss your my cell phone number.
NeverSatisfied02
08-03-2012, 02:58 PM
I didn't put mine under the arm rest because i have some RCA cables run under there already for the bass knob to my system. Where i put it is easy access should I ever want to use the aux inputs on the module and worked perfectly for how i wanted to route my wire to the cup holder to use my ipod. And when its not in use, it tucks nicely between the console and passenger seat so its not an eye sore.
