Drag Racing Tech - Kirkey's on stock seat tracks?
eb02z06
08-03-2012, 07:13 PM
Anyone have any pics of Kirkey's on the stock seat tracks? Or any track that allows movement front and back like the stock seat?
TIA!
studderin
08-03-2012, 09:15 PM
not sure of a c5 but a Fbody they were be really high up. unless your short its gona be tough getting the helmet on and off. And It hit the T top trim, I mocked it up.
and there not made to be movable, and should be fixed back mounted to be safe
98CamZ28
08-06-2012, 08:51 AM
I plan to, wanted to get to work on it this week, but it may be next week. When I do, i'll post some pics.
Edit - didn't see the C5, probably not applicable :)
ezstriper
08-06-2012, 02:19 PM
I have a pair of seat tracks that were modded to fit lightweight poly type seats, and are movable could drill a couple of holes to fit whatever...sell the pair for $50 ezstriper@aol.com Rob
1lejohn
08-07-2012, 03:03 PM
I have kirkeys mounted on the stock NON power drivers tracks. it will move fore and aft and also rock up or down. I have an adjustable seat back bracket which mounts to the cross bar. I'm 5'11" no problems with clearence. I wanted my seat to give me good support under my thighs and to have a slight rear rake. It might matter which seat type you have. I have the lay back Pro design.
I had Corbeaus and don't like the seat setting flat on the floor. It puts alot of strain on my back.
On the Pass side I took the track apart and got rid of the slide. I drilled some holes in the bracket and mounted it. I still need to put a seat back brace on it.
Heyfred
08-07-2012, 05:14 PM
96 chevy Lumina manual seat rails is what I used.
http://i62.photobucket.com/albums/h109/Dyno65/DSCN3597.jpg
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
