18" tire question
18" tire question
getting ready to order a set of 18" 9.5 rims this weekend but idk what tire size would work 275/40/18 work all the way around or shound i go skinner to a 275/35/18 p.s. its stock ride height but when i get the new shocks/struts in lowing about 1.5 inches
Do 275/40ZR18's.
275 = section width in MM (1 inch equals 25.4 mm)
35= sidewall height 35% of 275mm
275/35 = Aspect ratio
I think the 275/35 would look a little short.
Look at 285/35R18s in rear & 275/35R18s in front if you like lower sidewalls.
Toyo makes the T1 Sport in both sizes, so Nitti probably does as well.
Cowpunk
Cowpunk
cowpunk i know what the measurments are im a service writer i do all that for a living. my man issue is 90% of the roads around where i live are pothole heaven and i aint about replacing bent rims. and yes nitto makes a 275/35 and a 275/40. plus i want to be able to rotate my tires. until oewheels comes out with the new style zr1s in 18" 10.5 for the rear
And, I've sold tires for 25+ years. 35's will have a shorter sidewall than 40's.
Potholes will still be tougher on the 35's than a 40's.
If you think the shorter 35's would look better, get them. That's what I would do too.
Cowpunk
I am lowered on Strano/Koni's and running a 275/40R18 in the front and a 295/40R18 in the rear. Looks perfect to me. I've had no problems with it but notice a slight rubbing noise when turning the wheel too far. Otherwise, I'd still do it this way all over again; 275/35R18's looks dinky.
35 gives the proper (stock) tire diameter with a 18" wheel. 40 series will give you a 1" larger tire diameter (about 4%), which may rub in the front and may also give you a problem with the speedo and/or computer.
does any one have pics withe the 275/40/18 or 275/35/18 on 9.5 wheel on a T/A
Yeah a 285/35/18(25.85"), is also within the stock height range and is recommended for a 18 x 9.5 wheel. The only down side is that you'll have less tire option and they'll cost more than the same tire in a 275/35/18.
Here's a few more stock tire sizes I forgot to add.
235/55/16 = 26.18"
215/60/16 = 26.16"
235/55/16 = 26.18"
215/60/16 = 26.16"
My suggestion would be to either run 275/35/18 or 285/35/18.
The 285/35/18 will fit... it will rub the plastic fender liner in the front just a little.
(I know because that size it what I as running.)
