Where do I put the 2 o2 probes on my turbo conversion?
Old 08-04-2012, 08:49 AM
80gus's Avatar
Default Where do I put the 2 o2 probes on my turbo conversion?
What's the best position for LH and RH o2 probe sin my conversion
Help, I've never done an injected turbo conversion before!
Old 08-04-2012, 09:47 AM
Outlaw666's Avatar
please tell me that youre going to have those wrapped and a blanket on it...I fear there might be some serious melting lol.
add them to the collector area, what is this going in?
Old 08-04-2012, 10:18 AM
Chris@CBR's Avatar
Put them just past the collector on each side.
It must be going in a rock crawler or sand buggy of some kind right?
That fab work looks amazing.
Old 08-04-2012, 04:39 PM
stevieturbo's Avatar
Explain the application and ecu you intend to use ?
ie, are the o2 sensors you are fitting widebands or narrowband ?
A wideband should be fitted in the downpipe some 18-24" at least away from the turbo. Widebands do not like heat or pressure, so you dont really want them before the turbocharger at all.
Narrowbands it will hardly matter much
Old 08-04-2012, 05:05 PM
80gus's Avatar
Yeah water cooled manifold cover and fuel rails, separate system.
It's going in a winch challeng truck, standard 02, standard computer.
So this exercise has been no help I have one person say collector the other say dump pipe.
Old 08-04-2012, 05:06 PM
80gus's Avatar
Yep, and thanks.
Old 08-04-2012, 05:21 PM
Who said the two different things ? re-read my post.
And given this is going into a totally non road legal vehicle ( I assume ? )...you really dont need any o2 sensors at all, especially factory narrowband ones.
Old 08-05-2012, 03:58 AM
80gus's Avatar
Thanks, i had one bloke say collector and the other say dump pipe, im thinking of just going the dump pipe, my tuner says there not needed, but will help if i can fit them.
Old 08-05-2012, 04:03 AM
They are not needed for your application.
And for a narrowband sensor, location really isnt that important as I already described.
Old 08-05-2012, 08:59 AM
Tally TransAm's Avatar
if your running open loop no o2's pre turbo and a wideband in the downpipe
if your running closed loop o2 in each side before the turbo after the collector and a wideband in the downpipe
Quick Reply: Where do I put the 2 o2 probes on my turbo conversion?
