General Maintenance & Repairs - power steering rack leak
coryratcliffe
08-04-2012, 10:12 AM
my rack is leaking right on the seal where the steering column meets i was wondering if i can just replace the seals or if i need to replace the rack... also does anyone have a how to on this?
coryratcliffe
08-04-2012, 12:10 PM
anyone?
Jr.Samples
08-04-2012, 03:09 PM
I just put in a new rack in my 97 Formula this morning. It wasn't bad. I do not know where you could even get seals for the input.
coryratcliffe
08-04-2012, 06:12 PM
Could you explain all you have to do I'm just trying to get a idea because I'll end up doing it I wouldn't dare let a shop touch my turbo ls haha
Conrad
08-04-2012, 06:37 PM
I just replaced mine today for the same exact problem. You can replace the seal but it's more of a PITA then anything else. Buy a solid used rack and pinion and sell your leaking one for cheap. Someone could use it as a core or fix it themselves.
There are 2 bolts going through the k-member holding it in (15mm bolt and 18mm nut). Take those out (I had to cut the driver side bolt because the oil pan was in the way, happened to have another bolt that worked). Pop the outer tie rods out and save the cotter pins (18mm nut if they're factory outer tie rods). Take the high and low pressure lines out of the rack (18mm). Finally, to get the steering knuckle apart from the pinion, there is one 11mm bolt where they meet, take that out. Then use a flathead screwdriver and stick it in the gap in the end of the steering knuckle and hammer it in (angled upward). This will spread the end of the knuckle to release it from the pinion shaft.
When you're putting the new one in, put the bolts holding the rack to the k-member in the opposite way you took them out (nut on top rather than on bottom).
I'd recommend trying to take the driver side rack bolt out FIRST before anything else. If it's running into the oil pan and will not come out, I'd try to look for another bolt before taking everything apart (unless it's not a DD). Because you will have to cut the bolt in half.
This should get you through the whole process. Good luck.
FirstYrLS1Z
08-05-2012, 10:56 AM
seal repair kit GM#26032824
jimbos'ss
08-12-2012, 04:58 PM
thanks! :cheers:
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
