Multimedia Exchange - 436rwhp with cam/bolt ons
View Full Version : 436rwhp with cam/bolt ons
Cjm1991
08-04-2012, 11:30 AM
Car has stock untouched 241 heads, ls6 intake, and pnp stock Tb. Full exhaust with cats, cam and lid. That's it. Longtubes, custom y pipe, Slp lm2. I'll post dyno sheet later. 02 ws6 m6 with 3.42s on 10 bolt, no track times yet still need better tires and weather before that.
http://m.youtube.com/index?desktop_uri=%2F&gl=US#/watch?v=KYhSbMpqqa4
Camaroking1996
08-04-2012, 12:33 PM
What cam is in it? Sounds badass!
Cjm1991
08-04-2012, 01:02 PM
It's a hydraulic roller, 2100-6800 rpm with 110+2 LSA.. I'll have to find exact specs on duration later tonight. Runs great but it's just good for racing, the huge lift makes it a pain to stop and go a lot. Car was tuned by Redline performance
adamantium
08-04-2012, 01:13 PM
Are those 22"s?
Camaroking1996
08-04-2012, 01:15 PM
Are those 22"s?
Are you retarded?
adamantium
08-04-2012, 01:36 PM
Are you retarded?
Sarcasm>you
sabersaw30
08-04-2012, 02:29 PM
Do you got the dyno sheet on that? Not trying to call you bluff but that is a lot of horsepower for a cam only car.Cam and head car barely does that. What kind of dyno was you on? That is impressive. Okay I did not read race only my bad.
Cjm1991
08-04-2012, 02:47 PM
I was pretty amazed at the numbers, it's probably due to the giant cam, but still the shop it was tuned at said it was the highest cam bolt on car they have ever seen. :drive: With a set of heads it was only going to gain maybe 30rwhp so cost vs hp ratio didn't weigh out when it's running like it does on stock heads. The rims are 19x275x10.5 and no they don't hook for sh!t. They look damn good tho when clean, car is lowered about an inch as well. Not much tire on the wheel, but it will soon receive a set of skinny/fat slicks for a couple passes at Gateway when it cools off. Hopefully the rear end holds up, car only just turned 80k miles, I think it's got a couple hard passes in it on the stock gears. 4.10s would probably kill it, not to mention be really annoying with the cam
adamantium
08-04-2012, 02:53 PM
Why would 4.10s be annoying? Is this a 6speed? atleast 3.90s are needed with a "donkey dick" cam. Its only commons sense.
Cjm1991
08-04-2012, 03:02 PM
Yes it's a 6 speed, with a z06 clutch and stock 3.42s. Donkey kick cam is a great way to describe it, very different from my stockish z28. So the shorter gear ratio will make it not buck so bad under 20mph? The main reason for the stock gears was to save the rear.
mikh338
sounds like my trex cam. those numbers are very high but thats great dude. love the color of car
KTK Z28
08-04-2012, 03:25 PM
Sounds very rowdy. Nice job man.
chadroosa
08-04-2012, 04:25 PM
car looks and sounds sick... have any pics of it?
adamantium
08-04-2012, 04:54 PM
Specs on cam? 4.10s are not THAT short on a 6 speed and not firmiliar with that but from waht i know bucking ensues at a certain RPM not speed. Yeah i can see your reasoning for saving the rear. If its not THAT big of a cam and you are having bucking issues you should look into another tuner.
Cjm1991
08-04-2012, 06:06 PM
Yea i got some pics, sorry guys still not home.. it has a wsq hood that hasn't been painted yet and a lot of stuff under the hood to make it look better. I'll post a good pic of the rims too
Cjm1991
08-04-2012, 06:08 PM
The rpms have to be around 1900-2k to take off smooth..the tune is nice I love it when WOT.
Cjm1991
08-04-2012, 07:22 PM
http://i48.tinypic.com/2mnrytl.jpg
http://i45.tinypic.com/351bx20.jpg
Ill post a pic of the hood and front in a little bit
adamantium
08-04-2012, 08:58 PM
Any tuner can tune a car to make power WOT, a good tuner goes beyond that. Tell him about the bucking that cam has to be MASSIVE if it bucks alot. If you can share some specs im sure some members will point you in the right direction.
HioSSilver
08-04-2012, 09:44 PM
What rpm are you turning it. 4.10 may be to much gear. With that kind of power you should be at 120mph+/- in the qtr. With a stock height tire @ 6800 I could only go 122 beating on the limiter to get threw the trapps. 3.90 or 3.73 also holds up better than 4.10. Nice ride!
BOBS99SS
08-05-2012, 08:22 PM
Honest with a big cam car and a m6 4.10s make such an improvement,it will help alot in the lower rpm range,those are beyond great numbers,i would like to see the dyno sheet as well, was that dyno giving an extra 25 hp that day lol
bad_408_vert
08-05-2012, 10:03 PM
whats your exhaust set up. sounds great
BOBS99SS
08-06-2012, 05:22 AM
Some helpful info, any mod you will do will make such an improvement, get some 4.10s that will help a ton, honest my car was a different car with 4.30s vs stock m6 gears1 7/8th headers and a good dual exhaust will help the car pull alot harder,my tsp duals made a sotp feel over my previous ory catback setyp,also fast setup will help as well,with my ms4 car every lil mod made such a difference, how high did you guys spin it to?also what was your injectors at?
RoadconeTuning
08-06-2012, 09:18 AM
FWIW i've seen 45x made with a LS6 cam and ported 241's... made 430 on a stock 04 LS1 cam.
HioSSilver
08-06-2012, 11:30 AM
^^^^^sounds like a very generous correction factor.
1mean96ss
08-06-2012, 12:50 PM
what are the corrected numbers ? Get some tires and come play with some of the cars in st. charles well see how it really runs.
SSpdDmon
08-06-2012, 04:51 PM
Nice car. The bucking is in the tune. This is my car in traffic with a Vengeance Racing Vindicator cam which has duration in the 240's and lift right around .600.
Tuned by yours truly, of course... :)
http://www.youtube.com/watch?v=CH6r1T36Whc
http://www.youtube.com/watch?v=U2MnX_ykLeo
stlz/28
08-06-2012, 08:49 PM
i have an ls1 motor with a fast 102 intake 92 mm tb, 30lb injectors , a k&n air fuel injection thing, 5.3 cnc ported and polished heads, a comp cams 228r cam and spring and pushrod set, it has yella terra rocker arms and pace setter long tubes with a or/y pipe and hooker exhaust, all running through a built t-56 tranny..... What kind of horsepower will i be looking at? thanks im fairly new to all of the ls stuff
adamantium
08-06-2012, 11:32 PM
Your cars badass man!
SSpdDmon
08-07-2012, 01:57 AM
Thanks! =)
Cjm1991
08-16-2012, 02:14 PM
Sorry took me so long to get back to you guys, been crazy at work ect.. The cam is a tsp torquer v3. Don't know about the correction factor, sorry. Car runs great I can say that much, having owned 100+ built cars in my 35 or more years restoring and building bikes/cars. Not the fastest out there, but for what it made it's quick. I really don't have time these days to go cruise/race but when I do I'll just take it to gateway so I really know how it runs.
Cjm1991
08-16-2012, 02:17 PM
The exhaust is QTP longtubes, custom y pipe with cats, and Slp lm2 catback with 3" tips
desertLS1
08-17-2012, 12:47 PM
Gorgeous car man! Enjoy it!
Put the CETA mod on it!
DoggyB22
08-17-2012, 08:23 PM
Not bad but its time to upgrade that 10 bolt! & throw some 4.10s or 4.30s in it! A must with a big cam. No dyno vid or pics of the sheet? What was the torque?
