LS1ROPER
08-04-2012, 03:18 PM
Like title says 1999 Trans Am, 408, M6 $13,500. Lost interest so here we go on the market. Car was bought in June 2005 with 41,000 miles since installing the 408 in Sept 09 may have put 1500 miles on car, AUG 2012 car sits at 50,400 miles. So there is 1,500 give or take few hundreds miles on the motor. Car made 476 rwhp "BEFORE" adding the TFS heads has not been Dyno'd since the new heads. Had TSP LS6 before. Also never ran on the track! Car also comes with Street and Track wheel/tire setup, 6 point roll bar that hasn't been installed, plus new carpet that also hasn't been installed.
Here are the Details
ENGINE
TSP 408 short block "Fully Forged"
TFS/TEA 235 heads
Pat G Spec'd cam 242/244 621/610 112lsa+3
Venegence ported 92 Intake PTM 92 TB
Kooks 1 7/8 Headers
Meziere EWP "Street version"
Racetronix plug and play Fuel system
42 lbs Delphi injectors
Yellow Top Optima
Trans:
Built 6 speed by Six speed Inc.
Textralia OZ700 clutch steel flywheel
Tick Adj Master
Suspension/Chassis
UMI K Member+Upper and lower A arms
QA1 shock single adj. front and rear
Qa1 300lbs front springs
PST aluminum Drive shaft
9" w/ 4.11 Detroit Locker
UMI Tunnel mount torque arm
UMI LCA adj w/BMR relocation brackets
UMI Drag Bar
BMR boxed SFC
BMR Panhard bar
Rear QA1 shocks have Madman relocation bracket for shocks
Stock rear springs
Exhaust
Magnaflow SS 3" w/off road Y
Flowmaster merge
QTP 3" elect cutout- hooked to a convertible switch inside car
Body/Interior
Raptor Hood
Gray Leather
Tinted windows
Pro 5.0 shifter
03/04 Cobra shifter knob
3 pod pillar gauge mount
oil pressure Auto Meter colbalt gauges
water temp
AFR gauge not hooked up but in the pod
Raptor Shift lite
Line Lock switch in ashtray
Contact with any Questions #3186133488 make me an offer I cant refuse!!
ENGINE
TFS/TEA 235 heads
Kooks 1 7/8 Headers
Yellow Top Optima
Trans:
Tick Adj Master
Suspension/Chassis
UMI Drag Bar
BMR boxed SFC
BMR Panhard bar
Stock rear springs
Exhaust
Flowmaster merge
Body/Interior
Raptor Hood
Gray Leather
Tinted windows
Pro 5.0 shifter
water temp
Raptor Shift lite
