Can I change my lug pattern?
So I am looking for something different on my 4th gen F-body wheel wise. I have found some aftermarket wheels I like a lot but their lug pattern is 5X114. A bit far off from the factory lug pattern of 5X120.65. I know that there are some wheels out there that will fit even if they are not exact but I believe the difference here is too great.
So I ask the question, can I change my lug pattern? If so how?
Spacer/adapters would work but if you wanted wheels with any width, you'd have to find some in the 65+mm offset range
Otherwise, new or redrilled axles for the rear... Im not sure how you'd modify the front hubs but I would think they could be redrilled too... if not, custom ones could be ordered. Dont forget, you'll need a new spare too
