DACTARI
08-05-2012, 09:18 AM
Hello All,
I'm hoping to get some feedback from you guys, given how much accumulated experience there is on here. I had my OBX headers installed by my local mechanic. Everything was fine for two days, then I started noticing a drop off in throttle response. I popped the hood and heard the tell-tale sound of a header/manifold leak-- that thhhck thhhck thhhck sound that increased with revs. Upon shutting off the engine, I heard a sucking sound like there was negative pressure being equalized.
This is only on the driver's side. Like I said, it was fine for a couple of days before the leak started. The mechanics used the gasket that came with the OBX headers. I realize now this may have been a mistake. I also don't know what kind of bolts they used-- I assume OEM.
When I noticed the leak, I was late for a meeting, and didn't have time to remove CAI and plug wires, so I couldn't get to all the bolts. I tightened the bolts I could get to. I could got a quarter turn on 3/4 of them. This diminished the noise, so I guess diminished the leak.
Today, I'm gonna remove the wires and CAI so I can get some room to work and try to tighten the remaining bolts. Hopefully, this will take care of the problem. However, I'm not hopeful.
I want to be prepared to replace the header gaskets and bolts, and this time I want to use the best available. My wife uses this car to transport our baby, so I want to minimize the chances of a leak as much as possible.
I found this awesome illustrated post on headers installation on cadillacfaq that was written by StealthV. I can see now why he is so missed around here: http://www.cadillacfaq.com/faq/answe...ers/index.html
In that thread, he recommends "Percy's Seal4Good dead-soft aluminum exhaust manifold/header gaskets were used, part number 66032", and "ARP stainless steel exhaust header studs, part number 434-1301". I plan to buy these, unless any of you guys have any different recommendations.
So, what do you guys think of the above? I'm slowly easing my way into doing my own work on the car, and I think this will be a good next project.
Thanks!
DAC
Thanks!
DAC
