Dynamometer Results & Comparisons - How can i make it To 400hp
redssmaro
08-05-2012, 11:13 AM
just wondering how can i make my 2002 camaro ss get over or atleast 400 rwhp. I bought this car down in las vegas about a year ago. And it put down 390rwhp. And i believe it was tuned it dynojet or something like that. In henderson nevada. They guy i bought it off of used it for daily driving.
Current mods are:
226/236 525.525 110lsa asa cam
Pacesetter longtubes, slp cats, 3 inch exhaust
80mm bbk throttle body
The oval k&n fileter ( not sure what its called)
Ls6 intake
My car is a 6 speed
Can i make more power just off a tune? Or what can i buy to push it over the 400 mark.
Camaroking1996
08-05-2012, 01:12 PM
Unless you have emissions, rip the cats out.
Or get a Chrs1313 ram air setup with a new lid.
Sprayed1998
08-05-2012, 01:45 PM
Remove cats and put a cutout on it, if that doesnt do it try a gm 85mm maf.
redssmaro
08-05-2012, 03:29 PM
So I would just need to take the cats off and maf? Would an under drive pulley be necessary?
Emersan
08-05-2012, 03:54 PM
The under drive pulley is probably not necessary, but it WOULD help.
garygnu
08-05-2012, 05:14 PM
you need the MAF.I second removing or gutting the cats ,and getting a good cold air intake and a UDP.
redssmaro
08-05-2012, 05:21 PM
Ok.so it doesn't seem too hard to pick up another10hp. I'll be getting a maf and ud pulley and taking the cats off. I dont like the cutouts so i wont be doing that. Now another question is how much do they usually charge for a tune?
Sprayed1998
08-05-2012, 07:54 PM
Tune will range from 3-500. Cutting ur cats out and welding in some strait pipes should not even cost you $50. Ive heard you can find the GM 85mm truck mafs and use a special harness that allows you to use it on your fbody. Just do some research and shop around.
Johnnystock
08-05-2012, 08:33 PM
What muffler you have? And I dont think the oval filter is the best thing in town. Get a 98mm LID and U/D pulley.
Or get a FAST 92mm ported and call it a day(I got 17rwhp from it).
redssmaro
08-06-2012, 12:28 AM
Ok so i should go with the slp lip, slp ram air vent thing under lid, and ud pulley. I have a slp maf. Just dudnt think it would actually give power. And i currently have the slp loudmouth 2 .
And how much is a fast 92 combo.? Or what is a good price to pay.
Im new to this guys so any and all info is appreciated/
02'Andy
08-06-2012, 01:28 AM
The slp lid, exhaust, and maf are fine, but don't feel like you have to stick with slp for everything else. The ssra or chris1313 are probably better ram air setups, and the slp ud pulley is just a powerbond pulley with a price mark up.
New fast 92 setups are running around $850, nick williams/ptm/whoever 92mm throttle bodies are around $300-350 depending on the vendor, so a 92/92 setup would be around $1200ish.
redtan
08-06-2012, 09:40 AM
Don't bother with the MAF, it's not going to do much for you and that's $200+ for nothing.
Keep the one you have, or toss it completely and go SD.
redssmaro
08-06-2012, 11:50 AM
Redtan: what do u mean go sd?
02 andy where can i buy those ram air setups? The ssra and chris1313
Id probaly wait a little on a fast for now. And do the pulleys come complete with belts and bolts?
redtan
08-06-2012, 12:33 PM
I mean don't bother spending $200+ on a bigger/fancier MAF that most likely will not gain you anything (unless the rest of your intake setup is optimized for that size).
If you're going to do anything, remove the MAF alltogether and have the car run in speed density (SD). That will get you a few hp by removing the MAF restriction completely.
Otherwise, keep the stock MAF and put your money towards other suggestions like better lid or ud pulley.
redssmaro
08-06-2012, 11:22 PM
Oh ok. Well it looks like i know what to buy now. Thanks for all your guys help. Ill be getting a ud pulley and remove cats. Thanks again
blk/slvr02ss
08-07-2012, 12:05 AM
UD Pulley i have seen 7rwhp out of one and hp for removing cats i never tried but did get 1/10 in 1/4 removing them.
bestlude
08-07-2012, 12:16 AM
dont get a MAF... waste of money for what you want..
I say go with a cut out and a new tune on a COOL day.. done
02'Andy
08-07-2012, 12:23 AM
It sounds like he already has the maf sitting around.
raysadude
08-07-2012, 01:30 PM
How much is your budget? If you're at 390 rwhp why don't just buy a set of 243 heads and call it a day. You'll be over 400 mark guaranteed.
