Carbureted LSX forum - swap help
View Full Version : swap help
cuda620
08-05-2012, 11:27 AM
Lots of swap info here,so im curious. Anyone give me some tips on putting a 2010 camaro LS into a 94 camaro Z28?? Mounts,manifolds etc. Anything helps. Just did a 6.2 Jeep swap,now this. Going to swap all from the 2010 camaro,,including automatic. Thanks for the help. Still looking for best timing for my carbed LS jeep. Thanks all. GREAT INFO SITE!!! LOTS OF SMART STUFF HERE!!!
NoSloZ_1
08-06-2012, 12:34 PM
Not sure but I've heard you will need a 98 and newer k member and steering rack. And maybe an f body oil pan. I love ls swaps! Good luck!
ZONES89RS
08-06-2012, 01:21 PM
Pretty much, the lt1 parts are not a good option for a Ls swap, I found out and regret not using Ls I member and other parts on a 95 z I swapped a 6.0 into.
cuda620
08-06-2012, 03:18 PM
Hmm, Really. I'm glad I checked here first. I thought it'd be kinda simple. didn't know I'd have to swap k-member and steering. I thought 94 and up camaro's were the same. You guys probably saved me alot of headaches. May just get an old car to put it in simpler. Thanks
ZONES89RS
08-06-2012, 03:46 PM
It is easier with the old vehicles, i did the 6.0 with a 95 Z and the manifolds woudnt even fit past the LT1 steering shaft without some work!
cuda620
08-07-2012, 04:12 PM
Were they the ss camaro manifolds?? how did you make em fit??
ZONES89RS
08-07-2012, 08:22 PM
They were 98-02 manifolds and I had to trim the steering shaft if I remember right.
