Rocker tightening sequence for adjustables?
Old 04-04-2004, 09:06 PM
Senior Member
Country Boy's Avatar
Default Rocker tightening sequence for adjustables?
What is the sequence for doing adjustable rockers? I dont want to have to turn the motor over 100 times to get all the rockers adjusted.
Old 04-04-2004, 10:47 PM
H82BBad's Avatar
I start on number one and then work my way back. I found it is the best way to not miss any.
Old 04-05-2004, 02:55 AM
Unaffliated Racing's Avatar
werd!....just have someone sit in the drivers seat and tell them to bump the key..easy way...if you need any help give me a call at work
later,
brian
Old 04-05-2004, 07:09 AM
michael101's Avatar
I made a remote starter switch for mine to use for rocker adjustment. I ran wire to the small term. on the starter solenoid, and a wire to the 12v(+) on the driver side. Using a push button you'll be able to 'bump' your way through a lot easier.
Old 04-05-2004, 08:03 AM
Senior Member
The motor is out of the car right now. I just didnt want to spin it over a bunch of times to get all 8 done. I was wondering if anyone knew the valve sequence like the SBCs for adjusting the rockers.
Thanks guys
Old 04-05-2004, 08:48 AM
P Mack's Avatar
can't you just use firing order? there might be a faster way, but this way you only have to turn it over twice at the most, 90 degrees for each cylinder.
Old 04-05-2004, 05:57 PM
Senior Member
I could, I was just looking to do multiple valves at one time like the SBCs.... Just being lazy and its a new motor.
Old 04-05-2004, 10:30 PM
66ImpalaLT1's Avatar
The most you'll need to turn it is twice. Set it on #1 TDC and follow the firing order turning the crank 1/4 turn each time.
Two rotations is not a big deal.
