etcts-v
08-06-2012, 07:16 PM
I completed a number of interior Suede Interior Upgrades about a year ago that I wanted to share. This is a fantastic way to upgrade the interior of your V on the cheap, just talks a little sweat and fortitude! Total cost for supplies was about $150, did the work in a weekend.
I wrapped all the pillars, headliner, some dash pieces as well as my entire trunk. A year later the suede still looks like new, it darkened the inside quite a bit which is a great compliment to the 15% tint, it's like Dark Vader car!
I ordered all my fabric from Your Auto Trim, here is a link to their suede headliner kits: http://www.yourautotrim.com/suheki1.html
They are a fantastic vendor, ship fast and great customer service. My advice is to order all your fabric at once as the shipping is what hits the pocket book the most. Also order more than you think you need, trust me you will be happy with having extra rather than not enough.
The fabric itself is foam backed with makes it not only easier to wrap and hide creases, but also provides a fantastic soft cushy final product. However, note that you only get one chance with the foam backed stuff as if you try to peel it back up to reposition it, the foam will stay stuck and the fabric will be ruined, plus you will have to sand off the foam left on the piece you are wrapping (did this a few times).
When wrapping, over cut your pieces and take your time making smooth passes with your had to prevent any creases. On the edges, just cut multiple small strips to wrap around, these serve as stress relief and make the final product look pro.
I experimented with a few different glues, here is the one that I like the best. It has very strong hold and it highly resistant to heat and moister. You can pick it up at Lowe's for $10 a can, I went through 4 cans. Spray both the fabric and the piece you are wrapping, let sit for 5 min until tacky then wrap.
http://i949.photobucket.com/albums/ad335/ellioth3771/079340687219xl.jpg
The pillars and dash pieces were easy to remove, wrapping the pillars was slightly challenging as they are funky shapes. If you over cut your fabric then you shouldn't have any problems. The most difficult pieces to wrap were the large pillars in the back by the rear window.
Another key thing to remember, especially when doing the headliner, is to not spray the entire piece of fabric, just do one half of the piece, then the other side. Handling large pieces of fabric full of glue is a pain in the ass!
Getting the headliner out was a biotch because I did it by myself. I pulled mine out of the passenger side front door. In order to get it out I had to fold it slightly which made some terrible ripping noise however the piece was fine. I did reinforce the slim pieces around the skylight with fiberglass on the back before I put it back in.
The other piece of this is painting all the plastic trim pieces, knobs and buttons. I used this paint along with prep spray and plastic primer.
http://i949.photobucket.com/albums/ad335/ellioth3771/2321-Gloss-Black.png
Results were great, got a good durable glossy black shine on everything. I painted everything including the seat belt guides, both roof light/control panels and all of the pieces on the sun visors.
At first I tried to dye the vinyl on the visors black using vinyl paint. That turned out horribly. So I stripped the vinyl off, seperated the two plastic pieces on the visors and wrapped each side. I then sandwhiched them back together and used some epoxy to hold them in place.
If you want to tackle this and have any questions please let me know, I would be more than happy to help!
Here are some final results photos followed by some in-progress photos.
http://i949.photobucket.com/albums/ad335/ellioth3771/276632d8.jpg
http://i949.photobucket.com/albums/ad335/ellioth3771/2718e059.jpg
http://i949.photobucket.com/albums/ad335/ellioth3771/934e63cf.jpg
http://i949.photobucket.com/albums/ad335/ellioth3771/255aff17.jpg
http://i949.photobucket.com/albums/ad335/ellioth3771/195933_1759540719967_558437_n.jpg
http://i949.photobucket.com/albums/ad335/ellioth3771/DSC02611.jpg
http://i949.photobucket.com/albums/ad335/ellioth3771/DSC02609.jpg
http://i949.photobucket.com/albums/ad335/ellioth3771/DSC02613.jpg
http://i949.photobucket.com/albums/ad335/ellioth3771/DSC02608.jpg
http://i949.photobucket.com/albums/ad335/ellioth3771/DSC02605.jpg
http://i949.photobucket.com/albums/ad335/ellioth3771/DSC02601.jpg
http://i949.photobucket.com/albums/ad335/ellioth3771/DSC02603.jpg
http://i949.photobucket.com/albums/ad335/ellioth3771/DSC02604.jpg
http://i949.photobucket.com/albums/ad335/ellioth3771/DSC02598.jpg
http://i949.photobucket.com/albums/ad335/ellioth3771/DSC02597.jpg
http://i949.photobucket.com/albums/ad335/ellioth3771/DSC02522.jpg
http://i949.photobucket.com/albums/ad335/ellioth3771/DSC02524.jpg
http://i949.photobucket.com/albums/ad335/ellioth3771/DSC02616.jpg
http://i949.photobucket.com/albums/ad335/ellioth3771/DSC02615.jpg
