'99 Z28 Fog Light Removal
I'd like to remove the stock fog lights and clean the lenses up a bit. Do I access those from above or below the car? It looks like there are two or three screws that hold each one in place.
Additionally, is there a plug-and-place replacement housing/bulb that will increase the distance of these lights? If I clean the lenses up well, then is there a better than stock bulb to use?
I searched, but didn't find much in the way of other threads.
Thanks
Bill
Thanks
Bill
You can take them out from the bottom and you can disassemble it to clean. I cleaned them on my 01 ss I didnt really notice a differance. I sanded and used rubbing compound and and a polish but they were pitted way too bad. Doesnt hurt to clean tho yours might not be as bad as mine were. As for lights hids are the way to go in my opinon. Hope this helps.
