98 PCM Bad?
Old 08-07-2012, 12:09 AM
frankmarroquin's Avatar
Default 98 PCM Bad?
OK im kinda lost here with this car i just bought... It is a 6.0 with 243 patriot heads. Theres fuel and theres spark but it doesnt start. Vats are deleted, Cam Position and CRank position sensors are both new but it just doesnt start and smells really rich. What you all think it could be? Bad PCM? Im not sure whats missing. Please help with this headache
Old 08-07-2012, 11:09 AM
salemetro's Avatar
More info needed. Did the car run when you bought it, or did you buy someone else's headache? If it did run when you bought it, how well did it run. Did the the no-start condition just recently happen? Did the car seem to have any issues leading up to the current problem?
Old 08-07-2012, 01:26 PM
Sorry, i bought it not running. I Did a compression text and everything checked out fine.
Old 08-07-2012, 02:37 PM
salemetro's Avatar
So from what you're describing, sounds like it's dumping fuel. Any codes being thrown? Also, since it was not running when you bought it....what did the previous owner say happened?
Old 08-07-2012, 03:41 PM
The previous owner said it was running fine then one day it just stopped. I flashed the CPU and its a completely stock file. And yes its flooding the cylinders. Till i forgot to mention that i charged the oil and i noticed there was gas in there too. And i also checked the timing dots and they were aligned perfectly.
Old 08-07-2012, 03:49 PM
salemetro's Avatar
Ported heads, and a stock tune file? Interesting.
Any trouble codes showing? That's the next logical step. Also, what's the coolant temp sensor reading when you scan it?
Old 08-07-2012, 08:27 PM
Bird's Avatar
Check that the TPS is not bad and telling the PCM that the throttle is open - could be fooling the PCM into dumping the fuel in.
Also, unplug your MAF and see what happens
Bird
Old 08-08-2012, 12:09 AM
MontecarloDrag's Avatar
Hook a pressure gauge. Open the ignition key and let the pump prime. Don't crank it.
With key still open, watch if the fuel pressure goes down. If it does, you may have leaky injectors, bad wiring or faulty PCM.
Old 08-08-2012, 05:39 AM
BLK02WS6's Avatar
Run a scan with the key on and the engine not running to check TPS, MAP, ECT and IAT.
Old 08-11-2012, 10:43 PM
Wow... I feel stupid lmao. PROBLEM SOLVED I just need to tune it now. I was going to start parting it out till i got the motor half way out and found the problem.
Old 08-11-2012, 10:44 PM
Thanks everyone for the help...
Old 08-11-2012, 11:50 PM
salemetro's Avatar
Sweet mother of god......looks like Stevie Wonder was doing the wiring.....
Glad ya found the problem....now get it sorted out and hit the streets!
Old 08-12-2012, 12:11 AM
Thanks and yes hopefully i get time to tune it tomorrow.
