rattling noise
Old 08-07-2012, 12:34 AM
ls1 fever's Avatar
Default rattling noise
driving my 2000 camaro ss tonight, started hearing a rattling noise at the same time oil pressure gauge dancing between 60-80. limped it home and parked it noise sounded like it was coming from the top end passenger side. any help please need it.
MY POSSIBLE IDEAS:
1) clogged push rod
2) bad rocker
3) bad lifter
4) oil pump on it's way out
Old 08-07-2012, 12:42 PM
Ronny_02_WS6's Avatar
The best bet it to take the valve cover off and visually check, if nothing seems wrong then it can be a bad lifter or the oil pump it's not supplying enough oil. Not sure Though.
Old 08-07-2012, 12:48 PM
mark21742's Avatar
Check your rocker bolts, and if they are all tight see if you have any excessive play in any of them....could be loose bolt, rocker spitting out its bearings, bent pushrod...hard to tell
