buying a 08 5.3 from a suburban today need info!
im about to go buy a 5.3 from a 2008 suburban,complete running motor has a small knock,im really buying it for the heads to use on my 98 camaro ss,just wondering if there compatable as the older 5.3's?
799 heads will have the same vale size but smaller combustion chamber as well as bigger int/ex ports...the 706 heads have even smaller chambers but they have smaller valves and ports compared to ls1 heads...unless u getting it cheap I wouldn't buy for 706 heads, but if 799 then it's a good deal
Oh nice score it's an l33 I believe if it's aluminum...so it has the good flat top pistons and floating rods so you should have no problem selling the shortblock since they are desirable...and no you don't want to use that truck intake since they are built for low end torque rather than peak power
