99BlkZ28
08-07-2012, 10:40 AM
Car is in good condition, interior is clean. Car runs great, never had any issues with it, and currently has 93k on the body, 30k on the motor, transmission, rear end. I have paperwork for nearly all the mods and services. I even have the original window sticker. Any questions you can give me a call or text preferred Ross 314-698-7472. Car is around 500rwhp, it was street tuned so no dyno numbers, and has never been to the track. note all a/c components are back on the car, just need to get the system charged.
Motor: Texas Speed Build; 404ci
Eagle Crank and Rods
Diamond Pistons (11.4:1 Compression)
Texas Giant Cam 248/254
LS7 Lifters Modified
LS6 Oil Pump
PRC LS6 2.5 Heads with PRC valve springs
Receipts from build totaling close to $10,000
Bolt-Ons
Pro 5.0 shifter with short stick
SLP Lid
Ported FAST 92 Intake Manifold
Ported FAST 92 Throttle Body
Magnaflow Catback
TSP 1 7/8 Headers
TSP catless y pipe
QTP electric cutout with turndown
Transmission/Drivetrain
Rear end Rebuilt with Torsen Diff and GM 410 Gears, new bearings, etc.
Stage 2 Transmission-upgraded forks, synchros, etc.
Textralia OZ700 Series Clutch (Steel Billet)
Brand new Tick Adjustable Master Cylinder
Brand new GM Slave Cylinder
Suspension
BMR Strut Tower Brace
Energy Suspension Bushings Kit
BMR Front and Rear Sway Bar
BMR Panhard Bar
BMR Sub-Frame Connectors
BMR Lower Trailing Arms
KYB Adjustable Shocks in rear KYB Adjustable Struts and Springs in front
Kumho 275/40/17s in front, close to new Kumho 315/30/18 in rear, close to new C5 Z06 Black Wheels with Chrome lip
Interior
Python Alarm System and key fob
Autometer Fuel Pressure Gauge
Autometer AFR Gauge
Autometer Shift Light
Pinoneer Head Unit
Exterior
Halo Headlights with HIDs
Black Corner and Turn Signals
Rk Sport Ground Effects
Drilled and Slotted Rotors
LS6 Oil Pump
Bolt-Ons
SLP Lid
Magnaflow Catback
TSP 1 7/8 Headers
TSP catless y pipe
Suspension
BMR Panhard Bar
Interior
Autometer AFR Gauge
Pinoneer Head Unit
Exterior
