revving to the moon?
Old 04-04-2004, 10:19 PM
Blorton's Avatar
Default revving to the moon?
Sorry for what I'm sure is a faq, but what steps and parts are needed to make an LS1/6 capable of surviving being revved way up there?
I'm doing an ASA/GMPP CNC LS6 h/c swap on a stock bottom end in the near term, but am looking towards a 427 after that. Other than going with a quality rotating assembly with an excellent balance/blueprint job, what do I need to look for if I love the sound of a proper 'merkin V8 revving it's heart out?
Any input on what a realistic rev limit would be for something that needs to retain some semblance of daily driver civility?
Thanks!
Dan
Old 04-04-2004, 10:27 PM
JoSeY's Avatar
stock...6700 safely 6700-7000 ur on barrowed time 7000+ better start looking for another shortblock.....
Built...as in like an MTI 427.....it just depends on how much money u spin....but you can usually get up to 7500 safely on a decently built motor.
Old 04-04-2004, 10:55 PM
98_1LE's Avatar
I spun a rod bearing with the limiter at 6600. I would suggest good rod bolts if as a minimum. I suspect that I stretched a rod bolt.
