Paint & Body Work - remove overspray from plastic
View Full Version : remove overspray from plastic
Nathan C
08-07-2012, 03:39 PM
I recently had part of my TA repainted and the bodyshop did an amazing job for the price. The only problem is there is a little bit of overspray on some of the plastic pieces in my engine bay. Is there a good product you would recomend to get paint off of plastic? Thanks guys.
My6speedZ
08-07-2012, 04:18 PM
Clay bar and if that doesn't work you can try some grease/wax remover cleaner.
stevesfbody
08-07-2012, 05:15 PM
^that or reducer
TyCZ28
08-07-2012, 08:52 PM
clay bar wont help him any.. those plastic pieces are textured so there wont be any bite.. try the reducer or paint thinner...
Nathan C
08-08-2012, 02:05 PM
Thanks. I'll try paint thinner this weekend on a small sopt and see what happens.
Whistler
08-09-2012, 07:47 AM
The more aggressive the solvent, the more likely you will soften and discolor the surface of the plastic. Start with wax/grease remover, that will do the job if the overspray isn't too heavy. If you end up needing to go to lacquer thinner, you may have to dust a light coat of satin black paint on some of the parts if a chalky finish is left behind. Good luck with it!
jlcustomz
08-09-2012, 11:18 PM
Brake fluid will eat paint & not plastic. So will Dad's easy spray paint remover from Ace Hardware.
LilJayV10
08-18-2012, 01:04 PM
Good post. :nod:
