Vehicle Classifieds - 1995 Pontiac firebird formula NJ lots-o-mods
Joonejune
08-07-2012, 10:41 PM
Must go, if it doesn't sell whole I will post it as a part out. Doing another build lost iterest in this its sitting in my lot... $5,500
QUICK VID:
1995 Firebird Formula LT4 - YouTube
Clean NJ Title
1995 Firebird Formula 5.7l V8 85k miles
Auto Trans >10 miles
Built Motor >10miles
NEEDS: Tires, negitive battery cable (one on there now is draining the bat), two headlight motors $35 bucks from my seller, rad hose.
HAS:
Motor:
5.7l lt1 350ci shortblock Cleaned, decked, honed and rebuilt by a local machine shop
Comp Cams Cc306-8
Clevite 77 NASCAR cam and main bearings
Speedpro chromoly piston rings
2.02intake 1.6exhaust trickflo valves
Ported and polished heads and intake, opened exhaust and intake runners
Trickflow hardened pushrods
Comp Beehive springs
Crane 1.6 roller rockers
Mezire Electric water pump (connected to ACC mode with relays)
Bbk 58mm throttle body
New sealed power lifters
Canton Tall valve covers
Canton road race oil pan
Melling hi volume oil pump
New knock sensors (Block and PCM LT4 KM)
New Low oil sensor
Accel 36lb fuel injectors
255 LPH Walbro Hi Vol Fuel Pump
Tr555 plugs
Fuel Pressure Guage
Msd pro billet tunable optispark
Msd 8.5mm wires
KandN cold air intake with spectere element
TRANSMISSION "the gold hammer" 4l60e automatic transmission with pwm and performance button. Professionally built to hold 700rwhp. The company eliminates the weak points and uses parts like Borg Warner parts, Transgo shiftkit, Corvette servo, 500 boost valve and new kevlar band
TCI street fighter 3400-3600stall
MISC:
New brakes and rotors
Lt1scanmaster
Custom madz tuned ECM
Strut tower brace
Red Top Optima Battery (1mo old)
New starter
New radiator
AC delete
EGR delete
New Bosch oxygen sensors (with extensions for LTs)
Pacesetter Long Tube headers
Custom exhaust 3in true duals into an x pipe and two magnaflow performance mufflers.
Custom made seat deletes
Lower control arms
Panhard Bar
Edelbrock torque arm
Polyurethane motor mounts and trans mount
Msd blaster coil
Trick Flow Intake Elbow
Thats off the top of my head, Car needs very little. Lots invested but it’s time to sell some toys. I won't entertain tire kickers, serious buyers are welcome to schedule and appt to come see it. Feel free to check out the video and email or txt any questions you may have.
I have a bunch of $$$ into the car
pm, or email artemoriverajr@hotmail.com
Joonejune
08-07-2012, 10:42 PM
Reserved post
Joonejune
08-10-2012, 10:47 AM
To the top
Joonejune
08-19-2012, 12:42 AM
Bump obo
