Drag Racing Results - 11.11 @ 123mph LQ9 Regal
View Full Version : 11.11 @ 123mph LQ9 Regal
06X6spdGTO
08-08-2012, 01:20 AM
Still have some issue with fuel and I think the carb is too small or the fuel pump cant keep up... Running Pretty lean we were able to come up with a 11.11ET @ 123mph with a 5500DA or so.....
Having some serious traction issues with the MT Et Streets so a swap to some 4.30's is in the works (should pull harder on the big end as well). Best 60' was 1.67 of the T-Brake
http://www.youtube.com/watch?v=g-mzXi3FgIc
sabersaw30
08-08-2012, 03:33 PM
Wow that joker pulls hard.looks like it is hooking pretty good.
06X6spdGTO
08-08-2012, 09:55 PM
Intial Hook is good if we leave on the 2step at 3400rpm. Once it comes to like it spins pretty hard. weve managed to turn the rim inside the tire @ 8psi about 8inches in one pass.
Im hoping the 4.30's will fix alot of our problems and make it pull harder on the big end.
