Dyno Guesses & Bench Racing Forum - estimate hp and 1/8 mile?
View Full Version : estimate hp and 1/8 mile?
lsxTAlemy
08-08-2012, 05:34 AM
hey guys i have a 99 trans am full bolt on. with full bolt on and 100 shot i ran 7.7x's in the 1/8 with traction issues. i just did 241 hand ported polished and chamber work to the 241 the porter claims they would flow equal to the ported 243, ms3 cam, 390 gear, spool, and connecting now the trans brake. dropped about 500 pounds off of her and counting. got about 150 200 more to take off. rest of the mods on sig. i will be runing it on and off the bottle 150 hit and a future 200.
what do u guys think it will run? upgrading tires before i take it out, to some bfgoodrich 28x10 or mickeys et streets .
lsxTAlemy
08-09-2012, 04:43 AM
noone?
lsxTAlemy
08-14-2012, 07:07 AM
100+ view's no input ?
ragtopz28
08-14-2012, 08:24 AM
Ok... I'll guess 6.8 @ 100mph (having to guess hp to wheels, final weight and dead hook) How about you give us your estimated hp, weight and DA?
I'd also like to know where the 650 lbs reduction came from:eek2:
lsxTAlemy
08-14-2012, 01:00 PM
ok, well the weight is estimated. i weighed everything i took out and it was around 360 pounds without carpet or seats. i took out everything from the front end. bumper support, ac, powersteering, gutted dash completely, changing sterring wheel. ditching stock seats for the plastic jegs one there 6lbs each vs 49lbs drive 46pass. taking out the rear bum support, the ttop hole, no wipers. that's all i can think of for now.
now power wise the porter said id be close to 450 the tuner says ill be close to the 500 range witch i doubt but that's the estimate on hp. plus a 150shot witch ill guess it will give me 100 to 120 hp to the wheels.
is this better? would u need some more info? id like to get the car to 3000 31somthing with roll cage done.
lsxTAlemy
08-14-2012, 01:02 PM
i have also dropped weight for 320 to 250 trying to get to 200 lmao
lsxTAlemy
08-14-2012, 01:04 PM
im sorry for the noob question but what is DA?
ragtopz28
08-14-2012, 02:49 PM
Density Altitude (google it and read for days!). Bottom line the lower the DA the better the car will run. My track is at 36' above sea level and the DA can vary from -2000' to +2800' depending on temp, humidity, baro pressure, dew point and grains of water. Go to www.dragtimes.com for the track nearest you. My bracket car will vary up to .5 sec. depending on DA:bang:
I8UR4RD
08-14-2012, 07:15 PM
youl make over 500 with a 150 shot with that cam, those gears, and those heads.
id say high 6.70-6.90's depending on your 60 foot. total guess.
lsxTAlemy
08-15-2012, 06:59 AM
from what i read on drag times the track is at 15'. ill read up on it and see what i can find. iv been trying to see what that meant for a while now lol. iv seen it every were and didn't know what it was.
yea i was hoping a mid 6 but im happy braking in to the 6's period on a street weekend car. i know i wont dead hook. i wasn't hooking before, but i will be trying the bfgoodrich 28x10.5 to see if i have better luck. my cuz has a set of hooisers that he can lend me also.
lsxTAlemy
08-15-2012, 08:06 AM
ok i looked up some more info these are the number for the next couple days estimate for the track
Track elevation: 91.9 ft.
highest
08/16 11:00 AM
Temp..................92
Humidity.............54%
Barometer...........30.00 Hg
Dew Point............73
Grains.................122.0
Air Density...........91.88 %
Density Altitude....2870 ft.
lowest
08/16 02:00 AM
Temp.................77
Humidity.............90%
Dew Point............74
Grains.................125.7
Air Density...........94.37 %
Density Altitude....1970 ft
ragtopz28
08-15-2012, 09:11 AM
As you can see..slight changes effect DA drastically.
Neither of those #'s will get you a personal best time.
You need negative DA (Jan. or Feb.) for your best runs.
Good luck :burn:
lsxTAlemy
08-15-2012, 12:27 PM
Good luck :burn:
thanks for the info man appreciate it. i hope this combo works out well. im just a lil worried about the diff but oh well ill take it as it plays along. hope to be procharged next year with a 9 in the rear.
I8UR4RD
08-15-2012, 05:20 PM
id just run a mickey thompson and then itd prob hook. buy you a gallon of pimp juice if not. play with the tire pressures. find out if it likes a little heat or alot. i dont know much about that particular radial. im feeling a 6.70 tho. the tq youll make off the line is going to need a serious tire.
lsxTAlemy
08-16-2012, 07:30 AM
pimp juice? im fairly new to this especially track. iv done alot of street racing before the hole track thing is new to me. iv only taken my car out 2ice 1st time got about 8 passes and the second time i got about 15 passes. track was dead and i enjoyed it. lol 1st time was all motor and the second was on 100 shot. the tires i listed are the ones i already have the bfgoodrich are right at there sweet spot now ans there 28x10.5 the mt slicks i don't really want to use tho and the hooisers my cuzin is willing to give them to me hooiseres are good right?
lsxTAlemy
08-17-2012, 11:53 AM
i was hoping to brake in to the 6's on motor is that what u guys are say or u guys talking about on bottle 6.90s ??? have to finish the interior and the ill weight the car see what it weights.
lsxTAlemy
08-21-2012, 07:01 AM
any one for the last question posted ??
lsxTAlemy
08-29-2012, 07:03 AM
no more input? id like to know a lil more. i kinda stayed with a doubt here.... almost done with the trans id like to know what to expect.
ragtopz28
08-29-2012, 01:45 PM
I'm sticking with my 6.8x on the 150 shot.
Get out there, prove us wrong and post it up :cheers:
lsxTAlemy
09-04-2012, 10:11 AM
ok no problem if i dead hook without braking the diff i think i hope a 6.5x i been seeing cam only ms3 go 10.50s
lsxTAlemy
09-11-2012, 11:51 AM
hope to get the car out to the track next weekend if everything goes right and post some number up
A.R. Shale Targa
09-13-2012, 08:53 PM
The Hoosier Quick Time 275 drag radial is actually the widest footprint IIRC
10.3" treadwidth. With a 150 shot I'm guessing like 6.60 eighth mile
