th350, crossmember, th400 spacer and mount
Category: Accessories
Price: $35
Location (State): MI
Item Condition: Brand New
LS Engine?: Fits LS Engine
Th350 cross member with torque arm relocation. This was made by BMR and I do believe is no longer available. But it lets you bolt the th350 right in with no modification. Torque arm relocation bracket has multiple mounting points to change pinion angle for better launches. $200 shipped
Spohn th400 spacer. You use this along with a poly mount to adapt a th400 to t56 cross member making it a direct bolt in. Never been installed I realized the cross member I bought was a direct bolt in as it was. 35$ shipped
Th350 racing transmission. I had this built by sharp automotive in Mulliken Mi. They build huge power transmissions daily. This thing held up to my turbo 6.0 build no problem. It was built to handle 1000rwhp. (still have the receipt with that on it) It has machined pistons to accept more clutches. clutches are blue frictions and tool steels. hardened input and output shaft, forward manual valve body, upgraded drum, sprag, and thrust washers. Transmission pan is the derale transmission cooler pan with autometer temp sensor installed. Transmission has about 150 miles on it when it was last pulled during which it saw 3 fluid changes with tci racing fluid everytime. I have it out now and am just ready to get rid of it. $500 dollars picks it up. Hell the cooler pan, valve body, and a th350 core would cost the same. Pick up only. I do not want to quote a hundred shipping inquiries. If you want a shipping quote it can be shipped from a business address in lansing mi 48917 without need for liftgate.
if you have any questions you can call or text me at 616-835-1464
