milled ported 243 questions
may be getting a set of ported milled 243 heads for a good trade on some wheels i have, but i'm wondering if they are too much for a stock bottom end. been doing a lot of searching but really hard to say. the guy doesnt have any flow specs or even know how much was milled which kind of concerns me and also doesnt come with valves. not much history on them.
if i get them i will be feshening up the lower end with new crank, bearings, and rings. will also be upgrading lifters, oil pump, pushrods, trunion bearings, and timing chain, and will be getting a good cam to match. ive read good things on the torquer v3 cam.
car is an 2002 camaro A4 with 92,000 miles and is my daily driver. mods now are lid, ported TB, full exhaust, ATI Dampner, poly mounts, 3000 stall for now but will be upgrading to a 3600-3800 soon along with built tranny, 3.42 gears, and some suspension
should i do the trade?
are they too much for stock bottom end?
go back with stock valves or bigger?
is it worth getting heads sent off for flow specs and get cam to match?if not then what cam?
am i wasting my time with these heads?
any and all advice is appreciated
these are the pics ive gotten so far. havent seen them in person yet
come on guys.... 59 views and no one has any advice?
i also have a LQ4 block sitting at home waiting to be torn down that spun a rod bearing. any thoughts with these heads on this block vs my stock ls1
I'm getting my 243's ported and milled as well for the lq4 I have... I'm debating on a cam still because idk what compression I'll wind up with. But as far as heads go.. I've hear people say that you could have the worlds worst cam and still make power with good heads..
thanks
