General Maintenance & Repairs - ideling at 1200-1500RPM
Jadedbird
08-08-2012, 08:45 AM
My car is ideling at 1200-1500 rpm. idk what is causing this, im guessing that it is either
1) my car has open headers and the pcm is telling it to idel that high to work off the extra gas
or
2) i did the traction control relocation and my throttle cable is in need of readjustment
or
3) i have no idea... everything has been messing up lately
help
Roarin_8
08-08-2012, 08:59 AM
Do the easy checks first, check the throttle cable, if the throttle blade is left slightly open it will cause the idle to raise higher.
Jadedbird
08-08-2012, 09:22 AM
ok. thats what i was thinking/hoping
how do you adjust it. i know where to adjust it but i dont know how.
LS1121
08-08-2012, 10:12 AM
vac leak
Jadedbird
08-08-2012, 11:08 AM
vac leak
whatcha mean?
blade2222
08-08-2012, 11:46 AM
Vacuum leak.
Bacon
08-08-2012, 12:27 PM
I agree, sounds like a pinhole leak in an intake seal or something.
Jadedbird
08-08-2012, 02:39 PM
so i need a new gasket for my intake then?
Bacon
08-08-2012, 04:38 PM
Not unless you've determined that's the issue. Vacuum leaks can happen I'm many places - have top find out if that's what's causing it and where its located
Bacon
08-08-2012, 04:40 PM
Wait, what kind of car is it? Why do you have open headers? Where are your O2 sensors at?
Jadedbird
08-08-2012, 06:36 PM
I have open headers because im awaitin my true duals to arrive. I have front 02s. Not rears tho
Roarin_8
08-09-2012, 06:36 PM
What kind of car is it? I suggested the throttle cable since you had mentioned that you had messed with the headers and that the throttle cable needed adjustment. Was the car idling that high before you did those 2 changes? A vacuum leak can do it also but if the car was idling fine before.......
Jadedbird
08-10-2012, 02:00 AM
problem solved thanks!
Roarin_8
08-10-2012, 11:15 PM
What was it?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
