Fueling & Injection - feed and return line size?
edge04
08-08-2012, 12:53 PM
I have a Rick's tank with built in A1000. The feed is at the top of that pump which I think is a -10. Have a -8 return fitting welded in with 2 vents
I am feeding a twin turbo, 68's, 408. 1000cc 95lb injectors. 1000 horse motor.
My plan was to run -10 all the way out the tank to the raills and then returnning with -8? Is that overkill? Should I run -12 to post filter and then -10 from there to the rail?
LSXBlazer
08-08-2012, 11:14 PM
i have a similar setup but only expecting 850hp, im gonnna run a -8 feed, then a -10 return to aid in cooling the fuel as it returns to tank. just my opinion. i think you will be fine on a -8 feed because even most say -8 will support 1400hp. just leave yourself some room. this might save you some money too since fuel hose and an fittings are made of gold lol
realsquash
08-10-2012, 09:55 AM
-8 would be fine. What fuel pressure are you going to run? You could probably use a -6 and not have any trouble.
edge04
08-14-2012, 09:36 AM
not sure what pressure yet as it needs to be tuned.
So to be clear, stick with -10 feed and -8 return?
KILLER-LS1
08-14-2012, 01:42 PM
if the tank is set up for -10 feed and -8 return, then use those sizes. There is nothing wrong with "overkill", and that isnt even overkill for your setup
Gfleck047
08-14-2012, 06:28 PM
I have a stock bottom end 5.3 s400 turbo hopen for 6-700 hp -10 feed -8 return I would rather overkill then under do it and not have to do it twice
edge04
08-14-2012, 09:54 PM
what is the thread size on the top of thw Aeromotie A 1000? Looks bigger than -10. Or is it and I can just put a -10 90 hose barb for push lock on there?
Gfleck047
08-14-2012, 10:30 PM
A1000s I believe are -10 I think u can get them in 8 also
trevmust
08-23-2012, 10:37 PM
Would -6 be ok.for under 500 hp? & anyone know.if its.illegal to use russel/earls braided lines in california? A lot of car laws in california are the same in camada. excuse my spelling, my phone is being difficult
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
