Cadillac CTS-V - My Oil Tempertature went above 300 Degrees
My oil temperature was above 300 degrees and the car was beeping at me with an exclamation point showing 320 degrees, I'm assuming this is some kind of sensor has gone bad? Oil is 50miles old and full. Car is stock except for catch can
NeverSatisfied02
08-08-2012, 08:02 PM
Bad grounds. Common problem. Mine did it all the time. Tightened them up and problem solved. My problem was at the ground right below the hood strut on the left side of the engine bay in front of the battery and behind the fuse box.
01_SuperSlow
08-08-2012, 08:09 PM
^^ What he said.
BudRacing
08-08-2012, 09:22 PM
Take the ground off and scuff up the area a little to recreate a solid grounding point.
furbe
08-09-2012, 05:38 AM
And if it keeps doing it, ignore it. I tried all the ground tricks, even installed an oil cooler and every
time I tracked my car the temp would hit 300+ on the guage.
As long as your water temp is normal there is no way the oil is actually 300
Stone17
08-09-2012, 06:47 AM
Turn the A/C and radio off. The temperature will drop.
It has to do with the alternator and the oil temp sensor wire.
You can take the car to the dealership to reprogram the computer.
Read this.
http://www.cadillacfaq.com/faq/answers/oilguage.html
RADEoN
08-09-2012, 07:23 AM
i actually had a sensor go bad.
BudRacing
08-09-2012, 09:51 AM
You can also take the ground wire directly from the sensor to a nearby grounding point.
NeverSatisfied02
08-09-2012, 10:10 AM
That's a good idea. I'll do this if I ever have that problem again.
heavymetals
08-09-2012, 10:55 AM
Read this.
That "fix" does not work.
It resets the "offset", but is only good for a small range and does not deal with the problem.
The ground by the hood strut is the main culprit, although it is not the only ground that can cause the problem.
furbe
08-10-2012, 04:33 AM
dIsC0nECt it
gearhead68
08-16-2012, 01:22 AM
This happened to mine 2 days after I read this post. I always wondered why the oil temp. hovered around 230-270 degrees, then all of a sudden it became erratic and the alarm went off.
Wire wheeled the ground bolt under the hood strut, scuffed the paint, applied some dielectric grease, installed the bolt and the oil temp. mirrors the water temp.
One would assume this can cause some other electrical gremlins. I would've never found this problem. Thanks again guys.
9t8z28
08-16-2012, 07:59 AM
What about your oil temp mirrors and water temp? Seems like you forgot to finish your sentence
wes8398
08-16-2012, 08:49 PM
Think he was saying his oil temp now mirrors (as in it's the same as) his water temp...
