Generation IV Internal Engine - Can you help identify this cam?
View Full Version : Can you help identify this cam?
ealvarez11
08-09-2012, 12:47 AM
Need your help in figuring out what this cam is out of. See attached photos.
87silverbullet
08-09-2012, 04:45 AM
Well putting the sprocket part # in google states that its for a 2007 5.3 motor so I would assume the cam is for the same
connecticut
08-18-2012, 11:19 PM
I didn't know the five threes went to single bolt cam's in '07?
The 2005 L33 5.3 uses a 3 bolt cam, although with the early LS2 style pickup on the solid cam gear, the cam sensor is out back like the LS1/6
http://www.lingenfelter.com/page/ls-camshaft-sensor-sprocket-or-gear-amp-crankshaft-relector-id-page
the above link is good start
