Sponsored by: DashLynx
glasstech hood install problem
Old 04-05-2004, 12:01 AM
bbz
bbz's Avatar
Question glasstech hood install problem
while the hood lines up pretty nice on each side but there are a couple of problems:
1. Before I installed the hood latch & release lever the hood is slightly too far back on the passenger side (3/16") yet both sides are evenly spaced.
2. When I installed the latch & release lever the hood on the passenger side doesn't go all the way down flush even with the fender. I've removed the 2 rubber, round "stops" and it improved somewhat. also, when I do close the hood all the way down the hook doesn't want to release.
Sound familiar?
thanks,
jerry
Old 04-05-2004, 06:13 PM
67SS&99SS's Avatar
Have you tried to adjust the hood latch? This can be adjusted on each side(two bolts hold it in place) or you can lower the whole thing. I wouldn't try dropping it too much on one side because your hood clip won't fall into the latch correctly. I installed a SS hood on my Camaro this weekend and I had to adjust the latch because my hood was too low, it was below the lines of the fenders. Hope this helps.
Quick Reply: glasstech hood install problem
