Cadillac CTS-V - Kicking it up a notch with AFR heads
tommycompton
08-09-2012, 12:04 PM
Just got these bad boys delivered: My whipple will be sitting on top of these; AFR 230cc strip heads 72cc chambers
8019 springs
http://i36.photobucket.com/albums/e29/tommycompton/d017f911.jpg
http://i36.photobucket.com/albums/e29/tommycompton/621b62f4.jpg
http://i36.photobucket.com/albums/e29/tommycompton/e8d94806.jpg
http://i36.photobucket.com/albums/e29/tommycompton/2158e98a.jpg
Cometic head gaskets
http://i36.photobucket.com/albums/e29/tommycompton/d1196d7e.jpg
Arp head studs
http://i36.photobucket.com/albums/e29/tommycompton/16547da6.jpg
Yella terra rockers
http://i36.photobucket.com/albums/e29/tommycompton/64e582c3.jpg
Here's a pic of homemade motor mounts, bushing is made of teflon. They are gonna replace my collapsed CS mounts.
http://i36.photobucket.com/albums/e29/tommycompton/b04f3f51.jpg
Now I just got to order lifters, trays, dowel pins and a pushrod length checker.
Probably won't be doing the install until fall sometime, but figured I'd post up a teaser.
lollygagger8
08-09-2012, 12:19 PM
Ammmmeerrriiiicccaaaa....fuck ya! Looks awesome and familiar.....talked to Tony Mamo huh? ;)
Wait til you get all the studs in. The block looks like Pinhead from Hellraiser :devil:
Skidmarcx
08-09-2012, 12:27 PM
Nice brotha... I like the mounts
lollygagger8
Pinhead stunt double
http://i132.photobucket.com/albums/q16/n2havnfun2/Heads%20Cam%20Intake%20TB/IMAG0873.jpg
NeverSatisfied02
08-09-2012, 02:34 PM
Nice! One day... Lol
For now she's on the bottle until I have something give up on me... Lol not too many other combos making my power for the money.
BudRacing
08-09-2012, 02:48 PM
Nice hat
vmapper
08-09-2012, 04:45 PM
not worried about the YTs breaking?
Nice choice on the heads.
itsslow98
08-09-2012, 09:46 PM
They are some great heads it'll pick up a lot with boost.
9t8z28
08-10-2012, 09:20 AM
Yella Terra user here. Whats wrong with Yella Terra's ? Why should he be worried ?
tommycompton
08-10-2012, 10:45 AM
Yes I was worried about the YT rockers, well after I ordered them anyway. Only then did I read about failures. Tony Mamo who I ordered them off said these are 3rd gen rockers and they are good enough for his car.
From what i have read the failures were a quality control issue from batches from a few years ago.
I'm running a stock cam for now and my spring rates should be below the threshold. So lets pray.
I would have stayed with stock rockers and a trunion upgrade but AFR uses bronze valve guides and I didn't want premature wear to be an issue.
tommycompton
08-10-2012, 10:48 AM
Lolly did you get the thick valve cover gaskets for your YT's?
vmapper
08-10-2012, 11:08 AM
Just let it be noted, there were several cases of the YT rockers actually snapping apart, same goes for scorpion. Are these still issues with todays batches?
The stock rockers with a trunion upgrade is the way I would go, but as Tommy has pointed out, if your sweep is large (high lift) with stock rocker type, it will wear out the soft bronze valve guides prematurely, and rollers relieve that geometry side stress...
If you have some bucks.. Jesel wont let you down.
Tommy: Powdered metal not an option with the AFR head?
9t8z28
08-10-2012, 11:55 AM
Im in the same boat. Trick Flow 215's with bronze guides. Every manufacturer has failures that get posted on here. You have to read all the reviews for all of the brands and decide what you want to go with. Just let it be noted, there were several cases of the YT rockers actually snapping apart, same goes for scorpion. Are these still issues with todays batches?
lollygagger8
08-10-2012, 01:25 PM
I just got stock ones. Do they hit without them?!?
If so, where do I get them?
DenaliXTC
08-10-2012, 02:14 PM
very nice... I run the AFR heads as well. 225 was the biggest back when I bought them but with all the port and polishing they are probably 255's now lol.
have fun!!
tommycompton
08-10-2012, 10:51 PM
Tommy: Powdered metal not an option with the AFR head? Not 100% sure but no where is it mentioned as an option, so I assumed it wasn't.
They are suppossed to clear, but when I asked Mamo he wasn't sure. I picked some thicker YT gaskets from him.
9t8z28
08-11-2012, 05:13 PM
Stock valve covers will work with no issues and no thicker gaskets are needed as well
lollygagger8
08-13-2012, 09:24 AM
Ok whew! Thanks fellas.
tommycompton
08-13-2012, 11:13 PM
anybody want to buy some gaskets? lol I'll probably keep them inase i go jesels or something and need the clearance in the future
lollygagger8
08-14-2012, 07:24 AM
Lol no shit.....I have some coming (not here yet) that I won't need as well.
