sfc front mounting points slightly caved in
Old 08-09-2012, 03:00 PM
Ws6Dnero's Avatar
Default sfc front mounting points slightly caved in
My sfc mounting point on the front are slightly caved in from being jacked up on and being set on jack stands. I have the UMI boxed sfc's. Anything i should worry about before i take it to get them installed???
Old 08-09-2012, 03:34 PM
SparkyJJO's Avatar
Marked. I'm curious about this too as mine are bent also for some reason.
Old 08-09-2012, 03:42 PM
Jeremy@RPMTransmissions's Avatar
You will need to get the car up in the air on a lift or really stable on jack stands. Then use a slide hammer with the angled attachments like this one below to pull the metal back into place.
http://www.google.com/products/catal...d=0CIEBEPMCMAI
Old 08-09-2012, 04:03 PM
SparkyJJO's Avatar
A shop should have that stuff then. Makes sense. Why didn't I think of that.
Old 08-12-2012, 04:55 PM
14k
14k's Avatar
I installed my founders sfc no problem and mine are bent like that too.
Old 08-12-2012, 07:20 PM
smooveZ's Avatar
I had that same problem. My buddie used a slide hammer and pulled them back flat.
Quick Reply: sfc front mounting points slightly caved in
