will 275 40 17s fit 17-8.5 rims
OP 275/40R17's were a stock size offered with 17x9 factory wheels. They should work fine on 17x8.5's although some brands may be better than others (some run wide some run narrow)
I've been looking at the same wheels as the op and had the same concern. Most of the zr1 wheels are 17x9 except the c6 zr1 says its 17x8.5. Idk what the deal is, that's the only reason I haven't ordered mine yet.
The C6 ZR1s are 17 x8.5" and the C4 ZR1s are 17 x9.5" .
If you want a wider wheels the 18 x 9.5s front and rear would look good!
http://oewheelsllc.com/s.nl/sc.16/ca...35/ctype.SS/.f
