Pony Exp.305
08-09-2012, 04:54 PM
I look for an hour to get information and no lucks...
I get new water/coolant temp. sensor #2695A 6388 and #126 or #129 Delphi stamped on side.
How much max.temp?
LS6427
08-09-2012, 08:53 PM
Temp gauges don't worth work a damn anyway. As long as you have a needle to look at you're good.
Go to rockauto.com and put in the year and make........they have it.
Reckless
08-10-2012, 09:03 AM
Depends on the year of the car. If it is a 1998 the temp gauge is fine, but after that they are mostly for looks. Also, I think the sensor went from 2-wire to 3-wire in 1999, so make sure you get the correct one
chrysler kid
08-12-2012, 11:08 PM
1998 had a two wire sensor
1999+ had three wire sensor
The only store to carry a sensor for the 1998 vehicles is oreilleys. Autozone and napa only carry the 1999+ sensor
