Le2 cam specs
Old 08-09-2012, 06:00 PM
1320z28's Avatar
Default Le2 cam specs
Just got a lt1 cam le2 236/236 .600 .600 107 lsa.
Anyone with any idea if this would be suitable for at least a 200 shot nitrous? Tried calling le no luck yet
Old 08-09-2012, 06:17 PM
96capricemgr's Avatar
generally SBC cams are dual pattern with more exhaust duration, and then generally a nitrous cam will have extra exhaust duration.
It will work but you could do better.
Just because someone else will say it for BIG shots of nitrous often a wide LSA is used, a 200 shot does NOT warrant that. I would suggest open headers or short extensions with a single pattern on such a tight LSA with nitrous though. Try and run that through mufflers with the spray less than 3" dual and I think you will choke it.
Old 08-09-2012, 06:27 PM
1320z28's Avatar
I picked up the cam for 100 bucks to have some fun with while I build my 400 shot 355. Just figured it would wake up the ol lt
Old 08-09-2012, 06:30 PM
wrd1972's Avatar
Thats the old as dirt Bret LE2 Cam.
I would pass on it.
Old 08-09-2012, 06:36 PM
1320z28's Avatar
I would pass on it.
I already bought it lol. Just to have something other than stock in a street motor.
Old 08-09-2012, 07:05 PM
1320z28's Avatar
So it's an all motor cam would require a high stall?
Old 08-09-2012, 07:52 PM
96lt1m6's Avatar
107° lobe Sep. Is not an N2o friendly cam at all. More N2o would come out the tailpipe than what what would actually be injested by the motor. That cam on a 110-113 would be sweet....
As it sits with those specs I would use that cam in an Lt1 with 11.5-12.8:1 compression and good heads.
Old 08-09-2012, 08:12 PM
Wicked94Z's Avatar
Blah blah blah. Caprice is right with the exhaust advice. If it had a 224 intake lobe would everyone cry foul? No! Advance the cam a few degrees, like a 104ICL and it'll run fine. Explain why you'd want the tighter LSA with a higher compression motor with "good heads"?? Seems you're a bit confused. I'd run some stiff springs with that.......... at least a 1520X from PAC.
Old 08-09-2012, 09:12 PM
1320z28's Avatar
So by advancing it and follow the open exhaust advise 200 is doable? It would be cool if I can use it with nitrous
Old 08-10-2012, 04:07 AM
Wicked94Z's Avatar
It'll do fine on 200 with mufflers and the cam retarded... it's not essential or critical. But advancing it and running a good header and tuned length collector will help ya get the most out of the combo.
Old 08-10-2012, 10:49 AM
1320z28's Avatar
I'm going with kooks 3" true dual exhaust system. Le trickflow heads and 24x conversion. I'd say my exhaust would be decent. Might just keep the cam in now. Got a th400 3800 stall I'll see how she runs when it's time
Old 08-10-2012, 03:56 PM
speed_demon24's Avatar
Ah the good old Bauer valve spring eater cams that are lucky to trap 115mph
Old 08-10-2012, 09:34 PM
Village Troll
SS RRR's Avatar
What? Bert Bowerz is teh man!1111
Old 08-10-2012, 09:57 PM
1320z28's Avatar
Well I'll see what it does for me. If I'm not happy reaching my goals which should be fairly easy. Than I'll get a custom grind by le
Old 08-11-2012, 09:19 AM
Rob94hawk's Avatar
I dunno. Seems like a lot of work to end up disappointed in the end. I would listen to these guys. They haven't steered me wrong from day 1.
Old 08-11-2012, 11:59 AM
1320z28's Avatar
There are mixed opinions from what I can see, Once I get a hold of Lloyd I'll post some feedback. I do agree with caprice and wicked, it isn't the best cam but if I can make it work I'd save a good chunk of coin
Old 08-11-2012, 12:11 PM
Rob94hawk's Avatar
Good idea on consulting Loyd! Let us know what he thinks.
Old 08-11-2012, 01:35 PM
englundjd's Avatar
According to Lloyd this cam would pull from 2500-6500 rpm on stock heads and would take a good dual valve spring setup. Idle would be very agressive (DUH) and it would take steep gearing and stall if auto. I didnt ask him about N2O tho
He didnt seem to excited to see me asking about it lol. I asked him how it would do and he was like "it'll be a cam" lol
I was looking at the cam also but decided not to take it lol
Old 08-11-2012, 03:58 PM
1320z28's Avatar
I've got a 3800 stall coming and that probably explains why I haven't received a call back lol. I like the advise I got from here, with the 24x system hope I get to tune it spot on.
Old 08-11-2012, 04:03 PM
1320z28's Avatar
There was a guy here who ran the same exact cam and went 11.1 all motor. Was selling his car a while back
Quick Reply: Le2 cam specs
