Brakemotive rotors and painted calipers pics inside
Old 08-09-2012, 08:51 PM
Turbo306Fox's Avatar
Default Brakemotive rotors and painted calipers pics inside
So I finally bought the brakemotive pads and rotors and painted my calipers and brackets let me know what you think
Old 08-09-2012, 08:54 PM
Old 08-09-2012, 08:55 PM
I will get a full side shot of the car when I get it cleaned up and post it up to
Old 08-10-2012, 09:05 AM
Old 08-10-2012, 03:25 PM
ZeeSNuttS's Avatar
very nice sir! I would have painted the hat as well, in time it will start to rust.
Old 08-10-2012, 04:28 PM
Brakemotive's Avatar
Very Nice!!!
Old 08-10-2012, 05:50 PM
bigbomber5's Avatar
Very nice! What brand of paint did you use?
Old 08-10-2012, 08:52 PM
I bought the duplicate color caliper paint kit with the little brush it works pretty good leaves some brush marks tho
Old 08-10-2012, 11:23 PM
Snake_Skinner's Avatar
Wow what a difference, Nice job!!! Try and get some shots of the brush marks when you post the full side shot.
Old 08-11-2012, 09:29 AM
Ok I will try to and that was duplicolor paint kit
Old 08-11-2012, 11:11 AM
dabest09's Avatar
I think it's zinc coated so it won't rust. But it wouldn't hurt to paint it.
Old 08-11-2012, 07:19 PM
Old 08-15-2012, 09:52 PM
Cheap Guy's Avatar
Glad I saw this post - I got my Brakemotive pads/rotors and was curious about what people are doing in conjunction with the install. Looks good - I went with slotted but not drilled rotors.
Could you have used high temp spray paint on the calipers? My car is pewter and I want to go with high gloss black, but I was thinking it would be easy to just tape off the area, prime then put on the final coat.
Did you change your brake fluid in conjunction with the install? I was thinking any spill fluid would pull the paint right off so I may swap out the fluid first.
I also agree with probably painting the hat, but I wonder if the clearance is so tight the paint would just scrap off or even prevent the disk from going on. Then again, with stock wheels, you really don't see the hat.
Quick Reply: Brakemotive rotors and painted calipers pics inside
