General Maintenance & Repairs - ABS light on after replacing shocks & struts?!?
RIP_SVT
08-10-2012, 11:07 AM
Okay so I had my struts and shocks replaced yesterday and ever since I got the car back the abs light is on and was on the whole ride home. Also the tracton control stays off and I have no idea why...anyone know what's going on here and know if it's a real fault with the abs or just a code that was thrown caused by uneven wheel spin? Last time this happened I was getting my smog check done but it went away after a half block...
Armageddon
08-10-2012, 11:22 AM
Sounds like a wheel sensor or it's wire was damaged during the installation. There's a magnetic pickup sensor on each hub that sends readings back to the ABS controller. If any of the 4 sensors cease to function correctly for whatever reason you'll get an ABS code and your ABS will be disabled until the system is complete again. Take the car back to the shop that did the work and explain your situation. They shouldn't have the first bit of trouble locating the problem with a scanner and if it was something they damaged, kindly ask them to remedy it.
RIP_SVT
08-10-2012, 01:11 PM
Do you think that's the only thing that might cause that to happen after changing shocks & struts? Im just trying to relay all this info to the one who installed everything...& should that computer tell exactly what's wrong?
metalmilitia606
08-10-2012, 01:22 PM
I agree. It is pretty easy to pinch wires or something else when doing shocks.
Armageddon
08-10-2012, 02:03 PM
I'm almost certain that's what happened. The ABS code should indicate which sensor is faulty.
BlackLS1Bird
08-11-2012, 04:27 PM
It could be that something got pinched or damaged, OR the mechanic may have removed the sensor to make more room to get the strut out and not hit the sensor, and simply forgot to reinstall it.
