Notices
Parts Classifieds This an archive of the older parts classifieds, please create a new listing in our Marketplace.
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Tremec TKO 600 kit for 67-69 F Body
Old 08-11-2012, 01:56 AM
awake1630's Avatar
Default Tremec TKO 600 kit for 67-69 F Body
Category: Drivetrain
Price: $3700
Part Fits: 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird
Location (State): NY
Item Condition: Used
Engine: Small Block
LS Engine?: Non-LS Part
Tremec TKO 600 - TKO-600 (Street) 5009 2.87 1.89 1.28 1.00 0.64
Tranny was sent into Hanlon transmission and had over 800 dollars worth of upgrades done to it.
Has brand new carbon lined synchro rings, Machined shift rails to eliminate 2-3 shift lock out.
Brass Tipped shift forks and many other upgrades to help the longevity of the transmission.
Pro 5.0 Shifter.
Comes with lakewood scatter shield and engine protector plate. SFI Approved
Comes with ram billet steel 168 tooth small block internally balanced flywheel for two piece rear main seal motor. SFI approved
Science Friction diaphragm clutch good to handle 550 ft lbs. torque. Full kevlar clutch disc.
X- factor aluminum crossmember for TKO into 67-69 F body.
Speedometer adapter to original cable.
Driveshaft with 1350 U joints. correct length for 67-69 F Body. SFI approved.
Will fit 67-69 F bodys no problem. Bolts right in.
If you add everything up the cost comes out to over 4000.00 dollars. This is a great savings in a kit.
Comes with necessary hardware as well.
3700.00 is a steel for all this.
Call or text John
631-806-3169
Old 08-11-2012, 12:42 PM
awake1630's Avatar
bump ttt
Old 08-17-2012, 11:16 PM
awake1630's Avatar
will seperate stuff if anyone is interested
Old 08-18-2012, 06:24 AM
weircc's Avatar
i just wonder if any of it would fit 2nd gen camaro if so im interested
Old 11-13-2012, 07:24 PM
ls1foxcoupe's Avatar
Is this new?
How much for it without Bell housing, clutch, flywheel ?
Old 11-16-2012, 06:11 PM
bucnasty's Avatar
if i can mount a t56 on that crossmember lmk and how much for that
Old 11-16-2012, 09:49 PM
Alvisracn's Avatar
Trans only price?
Old 11-20-2012, 10:37 PM
awake1630's Avatar
Trans Sold. Bellhousing Sold. Driveshaft sold.
Old 11-20-2012, 10:38 PM
awake1630's Avatar
Crossmember 200.00 shippped.
Flywheel 150.00 shipped.
Attached Thumbnails Tremec TKO 600 kit for 67-69 F Body-apxm679f-2.jpg   Tremec TKO 600 kit for 67-69 F Body-img_0828.jpg   Tremec TKO 600 kit for 67-69 F Body-img_0827.jpg   Tremec TKO 600 kit for 67-69 F Body-img_0738.jpg   Tremec TKO 600 kit for 67-69 F Body-img_0739.jpg
Old 11-21-2012, 05:31 AM
awake1630's Avatar
Ram billet steel 168 tooth small block internally balanced flywheel for two piece rear main seal motor. SFI approved
Old 11-21-2012, 10:18 AM
I'll take the crossmember. PM me for details
Old 11-25-2012, 07:41 PM
awake1630's Avatar
Flywheel and Crossmember still for sale
Quick Reply: Tremec TKO 600 kit for 67-69 F Body
