Carbureted LSX forum - Anybody tried Summit Racing carbs?
Houston_t
08-11-2012, 07:32 AM
Given that I'm on a pretty tight budget I figured I might pick one up for my LS2 swap project when the time comes, they run $250 for the 750 cfm and that's right up my alley price wise. So I was wondering if anyone here has had any experience with them on their LS swap. My car will be built as a street cruiser, won't see any track time, all stock block with maybe a cam upgrade and ported stock heads in the future.
speedtigger
08-11-2012, 02:25 PM
Post a link. If they are what I think they are, they are an old Holley design that never caught on.
Prorac1
08-11-2012, 02:29 PM
Yeah, IIRC its the old holley 4010? spread bore design. Meant to bolt on to an edelbrock/carter AFB flange IIRC. You see a lot of the old holley ones at swap meets. Just different enough from a 4150/4160 to be a pain IMHO. Eric L
Prorac1
08-11-2012, 02:31 PM
I think this is what hes talking about.
http://www.summitracing.com/parts/SUM-M08750VS/?rtype=10
Prorac1
08-11-2012, 02:37 PM
IMHO, carburators are like cars or engines, its all personal preferance. Just like small block chevrolets, the holley 4150/4160 series has an ENORMOUS amount of aftermarket support and is widely understood. But for a street cruiser any properly jetted and tuned carburator will work just fine. Eric L
speedtigger
08-11-2012, 02:42 PM
I remember when those came out. I remember they were a little lower in price, they touted how you could change the jets and what not without spilling fuel. I never tried one. I just know that racers did not like them.
Prorac1
08-11-2012, 02:48 PM
We picked up a 1973 Camaro Type LT that had a paint job out of the 80s (even laquer, lol) and a greasy orange smallblock with one of those on an old edelbrock torker intake with an edelbrock pro flow air cleaner. A true power house it wasnt, but it was a trip back to my child hood, lol. It even had the L60s wraped around some Crager SSTs, lol. Heres the icing on the cake...............................There was still an REO speedwagon mix tape in the casette deck..................Clarion of course, lol. We rocked out with our faux mullets swinging in the breeze....................good times, good times, lol.
Childhood memory montage over. Eric L
speedtigger
08-11-2012, 02:55 PM
HA! Eric. Ridin' the Storm Out!
Prorac1
08-11-2012, 06:13 PM
LOL, LIVE............................................AL RIGHT PEOPLE, LAST SONG, lol.
Houston_t
08-12-2012, 06:29 AM
Yea that's the carb I was talking about, if I don't go that route whats a good carb that won't break the bank ?
Pop N Wood
08-12-2012, 07:08 AM
There was a thread on here about a month or two back talking about the summit carbs. Summit bought the rights to make that carb from Holley. They are an improved remake of an autolite carb Holley made for Ford. My buddy has them on his boat.
Do a quick search on the old thread. Lots of guys really liked those carbs.
For a cheap carb get a used one. You should be able to pick up a used carb and rebuild it for well under $100. There is another currently active thread where guys are swearing by quadrajet carbs. Say they bolt and go with no tuning.
NoSloZ_1
08-14-2012, 12:33 PM
Yea if your just looking for a good cruiser and not worried about max performance, definitely try out a q-jet! They do very good on gas and they are really streetable. I just put one on my 5.3 in my truck and love it. Save your money for now and track one down and try it out. For as cheap as they are and easy to find its a good idea to throw on and test out. You might be surprised,
slinginrods
08-14-2012, 02:17 PM
man i built a .060 over 350 stock bottom end flt tops ,with 305 h.o. heads on it with a 272 comp cam and a performer intake,long tubes 3.73 gear ,astro van posi,all used stuff with that carb.750i believe.put it in a 87 monte ss full weight it ran low 13s.thing had huge bottom end thanks to the large displacement and small heads,instant compression due to the small 58 cc chambers.carb worked great!! for a mild build id use it.and yes its just a remake of a 4bbl autolite ford carb,but upgraded.
Houston_t
08-14-2012, 02:51 PM
Is there a certain model quadrajet I should be looking at, Wernt the ones from the 80's electronic ?
Houston_t
08-14-2012, 02:53 PM
Slinginrods what do you mean by astro van posi ? Will the astro vans rear end fit in a g body ?
NoSloZ_1
08-14-2012, 03:47 PM
Just look on cl or in junkyards for a q-jet. The one I'm using is off of a late 70s camper with a 350 in it. It seems to work good for me. I have heard that gm used some larger q-jets on the big block cars and trucks in the 70s and early 80s so for you those might work better. Look around for an old gm truck
With a factory big block and q-jet. I'm sure you can pick one up cheap. I had to buy a 17 dollar adapter to be able to use it on my victor Jr intake. You will still be money ahead though! Also the astro van rear won't work in your g body. Your rear end is most likely stronger anyways.
Houston_t
08-14-2012, 04:45 PM
Thanks for the info. I want to put a posi rear end in my car but can't justify paying what people are asking for grand national rear ends for a street car, any other options ?
slinginrods
08-14-2012, 08:10 PM
If you have a 7 5/8 rear it will fit,if you have a 8.5 rear you have a strong rear anyway just put a posi in it.the astro uses the same rear as the82-98 camaro and 78-87 monte Carlo ,cutlass,grand prix,regal ,s10 ,blazer only the grand national got the 8.5.it's a ratchet type posi ,it's not that strong with slicks .the 4 cylinder s10 you could get 3.42,3.73,4.11.thats where I got my gear.
slinginrods
08-14-2012, 08:13 PM
Oh yeah went 10.60 on a 7 5/8 rear with a big block in my 86 z foot brake,but the trans brake and a 275 shot killed it. On slicks.pm me ill tell you how to make em live.
slinginrods
08-14-2012, 08:16 PM
Let my clarify,the housing won't fit only the carrier and gears will.as for the carb.elect quad started in 1981. Try to stay in the early seventies or late sixties if you can.
MikeFSKSpeed
08-14-2012, 10:54 PM
THe cheapest really good quality carbs I've found so far are the Proforms. No such luck for my customers running the Summits
NoSloZ_1
08-15-2012, 06:45 AM
Yea the housings are different is what I was telling him. Like you said if he has the 8.5 he is better off just swapping a posi unit in. Even if its the 7.5 it can still live with the right parts and modifications.
Houston_t
08-15-2012, 06:49 AM
Yea I have a 7.5 how can I build up what I have ? Not putting slicks on it or taking to the track so I'm not really looking to dump too much cash into it maybe a couple hundred bucks at most.
NoSloZ_1
08-15-2012, 12:04 PM
Yea if your not running slicks it should be fine. I've heard of some guys using the posi units and gears out of the 4th gen f bodies. They hold up well. Also invest in the rear end cover that has the bearing supports in it to keep everything from flexing.
