Dynamometer Results & Comparisons - 477rwhp Lq9 milled 317's and a cam
IllusionalTA
08-11-2012, 08:57 AM
Posted a bit back bout getting my car goin after taking a break for 9yrs due to life, worked the bugs outta the efi , had a bad computer from sitting so long In the heat.. Anyway, details of my experiment:
29k mile 6.0 escalade short block
Super Vic with 4bbl tb
Milled 317's .075 no port work , stock valves
250/250 HYd roller specd by my buddy Bret Bauer..
Coan 5k stall 8" converter
Th400
S60 with 4.56 's
All tuned by me..
All in all I'm satisfied with how it all turned out, ESP for the minimal $$$ I have in the conbo.. The sheets std car made 450sae for the sae guys, this is the first sheet he printed...
http://i665.photobucket.com/albums/vv17/IllusionalTA/6d0ab6cb.jpg
jims z
08-11-2012, 09:48 AM
How big a tire you running with those 456's and how high do u plan on spinning the motor? Great job on a fairly low budget motor!
IllusionalTA
08-11-2012, 10:29 AM
28"... See how it comes together at other track, I'll probably have to step down the gear a bit..
dgcustomz
08-12-2012, 05:41 PM
Were the cylinder heads angle milled?
IllusionalTA
08-12-2012, 06:19 PM
They were not rolled.. Flat .100
The torque doesn't look right. Peak looks low, but it looks like it was low everywhere else.
I'd be interested in seeing what happens when the cam is advanced a couple degrees, if there is enough P-V.
IllusionalTA
08-12-2012, 06:45 PM
I can do that fairly easily, my buddy used to own a dyno, and this wouldn't have a been a issue to play around.. P2v shouldn't be a issue.. i got room +/-10 deg.. :)
dgcustomz
08-12-2012, 07:17 PM
damn, So what about intake alignment? No issues? We milled 317's down .060" and had to fix the bolt holes on the intake. Bolts were going on sideways but it was worth it. 464rwhp.
IllusionalTA
08-13-2012, 05:56 AM
Intake was milled and redrilled
dgcustomz
08-13-2012, 06:27 PM
ah! now it makes sense to me. :cool:
IllusionalTA
08-18-2012, 09:19 AM
:cool:
IllusionalTA
11-13-2012, 06:46 AM
Just a update , I jumped in on a rental yesterday.. Never installed any of my rear suspension stuff. So I paid for it.. Either way was a good time.. Car went a best if 10.51@128 with a 1.47.. Rear of car wouldn't hold any more.. And my rims were spinning in my tires.. Made 16 hits, and had a blast..
http://youtu.be/lAvcaCiHukc
http://i665.photobucket.com/albums/vv17/IllusionalTA/713D4C18-D709-4995-B577-86EA56E659E9-1127-0000005C4582B791.jpg
Rob94hawk
11-15-2012, 07:21 AM
Real nice run Steve! Incredible 60ft!
IllusionalTA
11-15-2012, 09:54 AM
Thanks rob , got a lot left to do in the 60ft.. First time out hard to complain.. But def gotta go back
LSFOX
12-09-2012, 05:13 PM
Can you tell me a little more about your combo....?
Standalone?
From what I have seen anything over .075 has PTV clearance issues... Were the pistons Flycut?
What was the weight of the car?
I am currently starting to gather parts to build my own LQ4 or LQ9 and this budget build is just what I am trying to duplicate.... in a 3100lb Mustang of course
Martin@Tick
12-09-2012, 06:31 PM
Good job Steve!
IllusionalTA
12-10-2012, 09:05 AM
Standalone?
Car weighs 3570 with me in it.. Pistons are flycut, running a stock PCM.. I have throw the car back on dyno, to ensure my afr and timing is optimal as I had to crank limiter up to 7k to get through traps, just did it safely to get through the day..
Martin@Tick
12-10-2012, 09:14 AM
You put new springs in it too and got rid of the valve float correct Steve?
IllusionalTA
12-10-2012, 09:25 AM
Yea I did swap the springs, have yet to throw it back on rollers since.. No rush since seasons over... But it'll get there... Been workin on the interior lately...
93camaro_zzz
12-13-2012, 12:01 AM
Nice word indeed! What all is done to your TH400?
IllusionalTA
12-13-2012, 05:00 AM
Nothing, just a rmvb , clutches, and a brake.. Nothing crazy..
Martin@Tick
12-13-2012, 12:21 PM
He needs a stall like my old one, then he'll be cooking with grease;)
you would pick up huge power just working that exhaust port a little on this thing. time to pull the heads yet???
IllusionalTA
12-19-2012, 08:36 PM
Yea gonna yank them this winter, for a set of nice 243's.. Should hopefully pick up some steam...:) unless uncle martin@tick needs me to r&d some stuff... ;)
IllusionalTA
12-19-2012, 09:07 PM
Of course.. ;)
be sure to keep up on how mine goes, im right at 48cc again with the chamber opened up to 4.07
93camaro_zzz
12-29-2012, 07:47 PM
I am subscribed to you. I am going to be running almost the same combo as you, however mine will be this:
370ci LQ9 @ 9.06:1 compression
AFR 225cc w/ 72cc chambers
Custom grind 236/232 114LSA cam
Pacesetter 1.75 headers
Edelbrock Pro-flo XT intake
TH400 with Cicle D 5K stall
Moser 9" with 3.50 gear
I only hope I could dyno as much as you did, and also hope I could get a sixty foot as good as yours.
I am just shooting for a goal of 6's in the 1/8th N/A.
Good luck on the rest of your build!
93camaro_zzz
12-29-2012, 07:49 PM
I have a feeling my 3.50 gear is going to be what kills me, I wish I had 4.56's like you. But this car is ultimately a turbo build car, so I need to stick with the 3.50's. :(
IllusionalTA
12-29-2012, 08:03 PM
Are u serious? My compression is quite a bit higher than,9.0:1.. And your running aftermarket heads... My junks stock...but your should run. nice..my 60ft was trash as well... I am subscribed to you. I am going to be running almost the same combo as you, however mine will be this:
93camaro_zzz
12-30-2012, 01:51 AM
That is the reason I put almost up in my thread. I realize your compression is higher....
IllusionalTA
12-30-2012, 08:08 AM
I didn't intend to come off as a ass... Just feel you setup is yards ahead of mine, and should perform pretty good as well, your just giving up a ton of power since your mostly designed for boost, running NA... I'm gonna spray next season, so hopefully can hang w/ some of these faster car's.. :)
Martin@Tick
12-30-2012, 12:00 PM
Not a chance!:D
IllusionalTA
12-30-2012, 12:24 PM
Not a chance!:D
Why u be so mean!
Martin@Tick
12-30-2012, 01:09 PM
Why u be so mean!
NO hood having, non good oil using...
IllusionalTA
12-30-2012, 01:16 PM
Take it back Martin! Take it back!
http://i665.photobucket.com/albums/vv17/IllusionalTA/20fa27c7-1.jpg
Martin@Tick
12-30-2012, 04:08 PM
Lmfao
93camaro_zzz
12-30-2012, 09:45 PM
Sorry, I guess I came off as an ass too. Just thought you were being sarcastic, because in all seriousness, I think my motor would probably only dyno a tick above 400 to the wheel right now. At least that is what my butt dyno and my trap speed tell me. I am leaving alot of the table with this low of compression, like you said. But I am just kinda in limbo between turbo builds, and I still want to race my car at the track, so I guess it is what it is right now.
Good luck with your car, I will be following like I said! :)
MoreHP
01-05-2013, 08:09 PM
The peak might be low but its definitely not at a low rpm - it is around 5800-6000 which means that the peak hp (if the induction/tune/valvetrain) is right should have been @ around 7300-7500... hmm should be more left in this combo if that is correct. Advancing the cam as mentioned looks like your next best move if you can.
It is either running out of flow, floating the valves, the tune or a combination of these three that is keeping it from peaking and I am sure you don't want to spin that stock short that high regardless. Don't get me wrong its ripping for sure just curious whats going based on that dyno graph.
What rpm are you shifting at?
IllusionalTA
01-05-2013, 08:49 PM
Had float, but swapped out the springs, and haven't gone back to the dyno since, I'm shifting currently 63-6500 and running it out the back @7k.. It's a out the box super Vic, stock castings.. I do have the ability to advance the cam, if I desire, this was just a interesting experiment.. I may throw it back on to play with the tune a bit, I'm pretty sure the float is gone and power might have a lil carried better.. Only went to track once, and despite the shitty 60 It was dead nuts consistent.. And reliable.. Gotta screw my rims, and ditch the stock shocks.. I'm putting heads on over the winter so, I'll never get to push this combo as far as I can take it.. But it sure was fun...
It's a 8" coan.. Flashes to 5300 or so..
Martin@Tick
01-05-2013, 11:02 PM
Shift that bitch at 7000rpm and have that converter loosened up to 5800 and let her eat!
IllusionalTA
01-05-2013, 11:09 PM
I'm gonna strap it back down soon. , as street tunin stuff sux , it blows tires off at anything below 100mph on the hit
MoreHP
01-05-2013, 11:14 PM
So as I figured you ran the car after you made the changes to the valvetrain. This would better explain why the listed RWHP and weight don't quite match the performance (mainly the mph) especially considering it was its first outing and the issues you mentioned.
Makes sense to me now.
Now go run some single digits with the new combo!
IllusionalTA
01-05-2013, 11:23 PM
Yea still haven't optimized the tune either , fuel was safe on the log, added a deg upstairs at the track it answered with another mph.. I'm sure I have some more power left up top , and still might run this combo when the tracks open up in early march .. Depending on if we move my shop where I put my junk together or not.. Ill keep this thread updated, I've heard it would run like shit when I mentioned this lil odd combo that I was gonna try.. Needless to say , I'm pleased with how it turned out .. This top ends goin onto my lil brothers 346.. Should be interesting
Martin@Tick
01-05-2013, 11:37 PM
Keep giving it a degree of timing after peak torque until it levels off gaining mph, back it off a degree and if it doesn't slow down any call it good.
MoreHP
01-05-2013, 11:39 PM
Interesting enough usually those most vocal about why it will not work either have never tried it themselves or better yet understand why it did in fact work.
http://i5.photobucket.com/albums/y175/Shiftit/photo_zps317545af.jpg
Isn't it aggravating when your ready to move on with a particular combo and all you can think of is the what if's? been there done that too many times. :D
IllusionalTA
01-05-2013, 11:44 PM
Yea the terrible part is living on Long Island with no place to go test locally , and frequently.. It's a excursion to hit the track.. And a small fortune in tolls.. Miss having Mir in my back yard ..
Well oddly enough the guy claiming it wouldn't work in all his ls1tech post count glory , hasn't said a word.. Whatever.. It's fun polishing a turd!
93camaro_zzz
01-08-2013, 04:25 AM
Hey Illusional, I am just curious, because I am also street tuning my car myself with HPtuners, how much timing are you running in WOT at 5K and up? Feel free to PM me if you would like. I am currently working on the timing in my car. Thanks! :)
IllusionalTA
01-08-2013, 05:57 AM
I'm running 28 as of this moment.. You probably can run considerably more being you have low compression , but take it slow and log log log ..
93camaro_zzz
01-09-2013, 09:06 AM
Thanks! Yeah I was thinking I could get at least a degree or two more with my low compression. I am only at 26* right now, but it is definitely not finished and I knew that. And I got really mad when I went to the track expecting to get alot of full WOT runs logged and get some really good WOT timing tuning done, but my laptop decided to die that day. So it is back to street tuning for right now until I hit the track again.
Thanks again.
1BAD98LS1
01-26-2013, 08:49 AM
LMFAO thats an understatement
IllusionalTA
01-27-2013, 06:46 PM
Well yea, you actually experienced it.. U know!
IllusionalTA
04-22-2013, 07:28 PM
Finally got around to strapping it back down see if in fact the float was gone with only change being the addition of PAC 1521's over the patriot extremes I had in there previously.. Float went away, and was rewarded with a additional 17whp.. Upto 477.. I'll take it.. These 317's are beast... Fwiw I'm only runnin 26.5* of timing still.. Was squeezing in on a buddies dyno time for my touch up.. Didn't really dig in... Here's the video
http://youtu.be/6uuVPOMJ1i0
http://i665.photobucket.com/albums/vv17/IllusionalTA/F624D539-652C-4FC4-BD10-FFC4271A1787-1085-0000005DA6A83680_zps88c724c1.jpg
1BAD98LS1
04-30-2013, 08:48 PM
477WHP with stock heads is f'n awesome, very nice! I wouldn't mind seeing numbers like that myself;)
My90Iroc
05-01-2013, 08:01 PM
The internet says this result is impossible but your winshield banner says otherwise.
IllusionalTA
05-01-2013, 08:20 PM
I'm the only one posting in my thread.. Shoulda put tsp in the title..
My90Iroc
05-02-2013, 07:29 PM
True :swing::swing:
Stumped1215
05-03-2013, 12:57 AM
Some are watching. :secret2:
offaxis
05-03-2013, 09:42 AM
Congrats Steve!
This car is a beast guys. This is no dyno queen. Its holdng it down on streets and is driven everywhere to race or just cruise.
Martin@Tick
05-03-2013, 04:37 PM
It's a turd.
:D
Lawhead
05-03-2013, 04:56 PM
The LS1tech guru's told me to expect 450 out of mine........
I'm sure they will be here to troll shortly.....
IllusionalTA
05-03-2013, 05:30 PM
No they won't.. They scurred of this thread...
Lawhead
05-04-2013, 08:08 AM
477rwhp out of untouched heads and a stock bottom end through a TH400.....
NAH BRUH YOU BE LYIN!!!!
P.S
Some kick ass numbers I just got my motor back finally (Some pics in my thread) and will be hoping to chance your numbers not only on the dyno but the track your car is probably one of my favorite cars on here!
1BAD98LS1
05-12-2013, 07:03 PM
Congrats Steve!
Yeah I can attest to that, dude is taking a car with a junkyard engine and truck heads and turning it into a near 500whp street car. Drove that shit myself and its def. a fun ride for sure!
93camaro_zzz
05-12-2013, 10:51 PM
Congrats on the new numbers!
Martin@Tick
05-13-2013, 08:04 AM
Atta boy Steve.
weldermike27408
05-13-2013, 04:35 PM
Stock heads are quite awesome....
IllusionalTA
05-14-2013, 05:50 PM
Changed cam the other day, see on Saturday how she picks up
http://youtu.be/uKqk3e1X-x4
Martin@Tick
05-14-2013, 06:15 PM
And you still didn't buy one from me....:(
IllusionalTA
05-14-2013, 06:50 PM
Nothing personal..my boy Bret treats me good.. We still friends?
1BAD98LS1
05-14-2013, 07:29 PM
477whp....stock heads.....man that cam that came out sure did perform nice....surely it needs a new home :D
Bench Racing HP nums for the new cam....491whp ;)
Martin@Tick
05-15-2013, 10:18 AM
No.
:cheers:
