Dyson350
08-11-2012, 10:52 AM
Been having issues with the car not turning over and the security light staying on when it won't start..also when I drive down the road the security light will come on and stay on then turn off at times.
Anyway I noticed the car use to beep twice when I locked it using the key fob, but a month or so ago it only beeped once. Not sure if this is a clue to what may be wrong. Right now I am attempting to just use a resistor to see if that will fix it. But I am thinking it may not be a key or cyclinder issue.
Also when I test the ohms of the key i get anywhere from 3.74 all the way up to 18. When the car wouldn't work I was testing the key at around 10+ ohms. I put the key in and it turns on, when I pull the key out and test it tests at 3.74 which seems like that is where it should be as that is the most consistent reading I have got while testing
