pck me out a meth setup.
Old 08-11-2012, 03:30 PM
Bobsmyuncle's Avatar
Default pck me out a meth setup.
specs are as follows,
5.3
gt47
th400
9"
pump gas street car, will be at about 25-27#s needing a unit that doesnt take up much space, something that is cheap as well, i dont need all the fancy features, but havent had to buy a system before, and wanna get it right the first time. i am thinking i will need 100% meth
some pics would be nice too.
Old 08-11-2012, 03:38 PM
Cam72aro's Avatar
I just got the cooling mist trunk mount setup in. It has the tank with the cubby hole that the pump sits in. It was $270 shipped. I got it off ebay. You can also look on their site. Its the basic trunk mount kit.
Old 08-11-2012, 03:42 PM
95maroz28's Avatar
is this an f-body? jw im looking for a kit too
Old 08-11-2012, 04:03 PM
01 ws6
Old 08-11-2012, 04:50 PM
+badss+'s Avatar
I went with snow stage 2 meth inj. kit for mine $400, but alky control is another and probably the best but cost like $600
Old 08-11-2012, 08:13 PM
got-a-ls1's Avatar
i went with the snows stg 1 boost cooler. i dunno IMO the electronic progressive units are definitely nice but i wonder if they are over kill... i have the biggest nozzle that snow sends in my setup and its triggered around 7-8psi. I have no hesitation when it hits or anything.. running around 75% meth by volume.. It completely cured my knocking and cools the intake charge at or below ambient temps... if you had a huge turbo thats slow to spool or a real small engine slow to spool i believe the benefits of the progressive units would be seen... but my pt7675 spools so fast on my little 5.3 that by the time it triggers at 7 psi its at 16-18psi less then 2 tenths of a second later. i just went 106.8 mph this weekend on a stock 5.3 bottom end and minimum 3850lb raceweight so im happy and i think it works awesome. best part i price matched with jegs and payed only 250 bucks...
Old 08-11-2012, 08:58 PM
Sales@Tick's Avatar
I will say that the Aqua Mist looks like one bad *** set-up, but alky control would get my vote also.
Now tuning it for the methanol injection....that's another can of worms in itself.
Old 08-11-2012, 09:24 PM
607motorsports's Avatar
I run a Devilsown 200psi pump universal kit and it has worked great for me.
Old 08-12-2012, 10:52 AM
NBM-LS1's Avatar
Alky Control is the only thing we put on cars. The customer service with Hulio is outstanding.
Its more expensive than other kits, definitely worth it.
Old 08-12-2012, 10:20 PM
bad6as's Avatar
are you going to run an intercooler?
x2 alkycontrol
Old 08-13-2012, 12:50 AM
itsslow98's Avatar
I run Alcohol Injection Systems trunk mounted system, no complaints the the pump is mounted uner the tank so now worrying about where to mount a pump.
Old 08-13-2012, 02:52 AM
Nitroused383's Avatar
Alky control is the only way to go if you want a reliable setup. Not bashing devil's own but I've personally seen them fail on other cars and will not tune them.
Old 08-13-2012, 07:31 PM
LT1RAY's Avatar
What universal kit are you running, the DVC-30 Stage 2 kit?
What failed on the Devils Own setups? The pumps? I was planning on buying their meth kit this week.
Old 08-13-2012, 08:17 PM
MIGHTYMOUSE's Avatar
Originally Posted by Martin@Tick
I will say that the fastest car I've ever owned had a Snow kit on it.
x2 agreed
Old 08-13-2012, 09:24 PM
Sales@Tick's Avatar
Originally Posted by MIGHTYMOUSE
x2 agreed
I see what you did there
Second fastest now....
We do sell a lot of the Snow kits I wish we did carry some other brands though. Nothing against them at all, I do like their new L.E.D. readout controller they have now.
Old 08-13-2012, 10:49 PM
NBM-LS1's Avatar
Alky Control has an LED indicator as well.
What usually fails is the pump. Some components internally can't handle the meth and corrode. Another reason why Alky kits provide brass fittings instead of aluminum.
Old 08-13-2012, 11:43 PM
ZNix's Avatar
AlkyControl is a great system. Almost every fast Turbo Buick out there runs it. Julio's pump has been modified to withstand methanol use. In his kit, you only use 100% meth (or as close to 100% as you can get). Most other pumps need a lubrication additive, etc. You can also use Denatured Alcohol if you have to, but it is more damaging to the pump. Very easy to install. I had a kit done in a day by myself, and I am 17 years old. Give the kit a go, you won't be disappointed.
Nix
Old 08-14-2012, 07:10 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
I went with the Aquamist setup based on how it's activated and metered. The setup is based on injector cycle duty rather than boost pressure, and I think their nozzles and injectors are a better design. They are almost like a fuel injector themsevles with a pump that pushes 160psi at constant pressure, then you have an electronic actuation valve that opens to the nozzles.
Aquamist has been running WRC's for years and years and is 100% methanol safe. After spending as much as I did for a forged shortblock, and a D1SC Procharger, a couple extra hundred dollars for a better meoh injection setup is worth it.
Old 08-14-2012, 07:13 AM
smokinHawk's Avatar
by my progressive kit
https://ls1tech.com/forums/parts-cla...kit-270-a.html
Old 08-14-2012, 07:22 AM
Sales@Tick's Avatar
I didn't necessarily mean the indicator light, I meant that they have a controller that looks like a remote control that has a L.E.D. readout display and has push buttons that allow you to cycle through menu's and options instead of having to fool with *****, dials or dip switches. It also will tell you exactly how much fluid is left in the reservoir.
Quick Reply: pck me out a meth setup.
