Drag Racing Tech - What gauges are you running?
View Full Version : What gauges are you running?
01_ram-air
08-11-2012, 07:34 PM
I have to buy a Trans Temp gauge but will eventually get two more gauges for my 3 gauge pod. I'm curious what gauges you are using and what brand/series. For example, if you're using Autometer... is it the phantom II series, Elite, Prestige, etc. What issues have you had... not working correctly, color doesn't work all the time, wish you went with the electronic sending unit, etc. Any advice or experience will be helpful.
GMRACER13
08-11-2012, 08:17 PM
Fuel Pressure and Nitrous Pressure. Do I have to do everything for you?
djfury05
08-11-2012, 08:41 PM
Dual Aeroforce with a wideband. Would of had fuel pressure as well but the fitting didn't have an o-ring provision for my fuel rails so fuel sprayed everywhere.
01wss6
08-11-2012, 10:31 PM
I have a full sweep electric trans temp gauge for sale on ebay
http://www.ebay.com/itm/170892418809?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Heyfred
08-12-2012, 09:49 AM
Speed Hut
http://www.speedhut.com/
http://i62.photobucket.com/albums/h109/Dyno65/Camaro/DSCN5248.jpg
http://i62.photobucket.com/albums/h109/Dyno65/Camaro/DSCN5250.jpg
+badss+
08-12-2012, 10:21 AM
here's what mine look like i also have my trans temp gauge down by the ashtray
http://i593.photobucket.com/albums/tt11/02BlkSS/55a2cdad.jpg
fex77k
08-12-2012, 11:29 AM
Pro comp Auto Meter, large tach, oil pressure, and coolant temp.
studderin
08-12-2012, 03:45 PM
shift light
thats it
TurboStangJON
08-12-2012, 06:11 PM
^Same here, logged everything else with a laptop.
01_ram-air
08-13-2012, 12:52 PM
Thanks guys... decided on going with the Auto Meter Ultra lite Digital series. Wideband, Fuel pressure, and trans temp. $654 total. :cry:
fex77k
08-13-2012, 02:22 PM
I also run a standalone pyrometer and LM2.
DietCoke
08-13-2012, 05:31 PM
Prosport evo gauges. NOTHING can touch them for the price.
RENE'S RAGE
08-16-2012, 05:51 PM
Is that the ES Series?
+badss+
08-16-2012, 10:02 PM
yes mine are autometer es series
c0ncEpT
08-17-2012, 07:01 AM
Phantom II
Trans Temp, Fuel pressure, and Boost.
RENE'S RAGE
08-17-2012, 04:19 PM
Thank you Sir!
I'm leaning toward the ES Series also. Because it lights up in red.
Trans Temp and Water Temp. Maybe Oil Pressure.
Where does the Oil Pressure Sensor go?
Do you take out the stock sensor or what?
subhumanzz
08-17-2012, 04:42 PM
http://i37.photobucket.com/albums/e73/mahogoff/ga.jpg
+badss+
08-17-2012, 04:46 PM
Thank you Sir!
Not sure. If it's electric it should go in stock location, manual may be different.
I love the look of the es series because the red matches theme of my car,
I'm using the boost,wideband,fuel pressure,trans temp gauges.
RENE'S RAGE
08-17-2012, 05:03 PM
Yeah, I'm going with the ES, because my dash lights up in red also.
DietCoke
08-17-2012, 05:21 PM
Thank you Sir!
http://prosportgauges.com/images/216EVOBO-PSI-R.jpg
PRosport evos light up red or blue (user selectable) and come with senders for $55-85. Much cheaper then aeromotive, digital, and super nice.
http://prosportgauges.com/evo-series-red-and-blue.aspx
JRracing
08-17-2012, 07:02 PM
Auto Meter Ultra lites. I think they are simple to read at speed.
Doobie52
08-17-2012, 11:57 PM
Innovate MTX-L Wideband, Autometer ES Series Fuel Pressure, and AEM Boost Gauge. Haven't tried out the AEM gauge yet but the others are excellent. The wideband and the boost gauges have outputs for data logging.
http://i616.photobucket.com/albums/tt249/doobie52/DSCF1714.jpg
RENE'S RAGE
08-18-2012, 07:12 AM
Pretty cool.
I'm wanting to mount the gauges in the A/C vents. I remember that someone made a fitting (adapter) that angled them toward the driver. So you could see them better, than being mounted straight in the vents.
Anyone know who make them?
SCott5
08-18-2012, 12:44 PM
those 2 1/16?? They look bigger
+badss+
08-18-2012, 02:42 PM
yep 2 1/16 gauges.
